Mini Turns Over But Won't Start!
Posted 20 December 2011 - 06:44 PM
The problem is that it turns over but will not start.
The engine ran for a short time after being built but did struggle to start.
I have checked the compression and it's 150psi across the board
I have checked the ignition timing and when it was running it was timed with a strobe
It's had a new distributor cap, rotor arm, leads and coil
I have checked the spark and gapped the plugs
Also getting fuel and there's over half a tank
I have also checked and I'm getting 13v to the coil
Posted 20 December 2011 - 08:46 PM
DOH!! I need to read more carefully.
Try some easy start squirted into the carb inlet and see if it fires.
Edited by zef, 20 December 2011 - 08:47 PM.
Posted 20 December 2011 - 11:00 PM
http://www.theminifo...howtopic=114176
Posted 21 December 2011 - 12:00 AM
Posted 21 December 2011 - 10:53 AM
I also had a thought last night but maybe the fuel is contaminated because the last thing I did before the car went up on jacks outside on my mates drive was to fill it up, I know it's a long shot but it has got gradually worse. Would unleaded in a classic engine cause any problems?
Posted 21 December 2011 - 11:10 AM
Posted 21 December 2011 - 04:52 PM
Posted 21 December 2011 - 06:37 PM
Posted 22 December 2011 - 10:47 PM
Posted 23 December 2011 - 02:43 PM
The mixture was setup with a colour tune plug
Posted 23 December 2011 - 08:48 PM
Edited by Realstoo, 23 December 2011 - 08:49 PM.
Posted 27 December 2011 - 03:22 PM
Any ideas?
Posted 27 December 2011 - 03:29 PM
Posted 27 December 2011 - 06:27 PM
And also the choke cable has seized, it was only fitted a month ago an has been working fine until now!
Posted 27 December 2011 - 11:59 PM
With mine the timing was out which I have got nearly spot on.
In the dizzy have you checked the points and the connectors, if its turning over it may not be firing the spark its self at the right time for instance the spark itself is firing between the top dead centre of the pistons, if you get me?
put it in gear and rock it with the dizzy cover off and watch the points and contacts, hope this has helped a little.
