Copper Brake Pipes
Posted 18 December 2011 - 09:29 PM
Posted 18 December 2011 - 09:35 PM
Was it the actual pipes that failed, or the unions between them?
This is the best input I can offer, but I'm sure someone more knowledgable will be along shortly.
Posted 18 December 2011 - 09:49 PM
Posted 18 December 2011 - 09:50 PM
Posted 18 December 2011 - 09:59 PM
Posted 18 December 2011 - 10:00 PM
Copper-nickel (kunifer is one trade name) is the correct stuff.
Copper does not have a fatigue threshold, unlike steel. Pressurise it a certain number of times and it will burst. You will get a number of emergency brake applications, or a much larger number of normal brake applications, but burst it will, well within the life expectancy of the average vehicle.
Kunifer is not as tolerant as steel of fatigue, so it needs to be clipped down well, with no flexing. But it will take an essentially infinite number of pressure cycles, and on balance, is safer than steel pipes, which corrode.
Aluminium is also not permissible, again due to fatigue, and stainless is just about impossible to flare without cracking, so it has to be steel or Kunifer.
Posted 18 December 2011 - 10:04 PM
Edited by brad-the-bear, 18 December 2011 - 10:05 PM.
Posted 18 December 2011 - 10:07 PM
Posted 18 December 2011 - 10:26 PM
brad-the-bear, I hope you have good public liability insurance. I fear that you are going to need it.
Posted 18 December 2011 - 10:41 PM
B. Brake Pipes and Flexible Hoses 1. Check that rigid brake pipes are securely held and not free to vibrate. 1. A rigid brake pipe inadequately clipped or otherwise supported. 2. Check all accessible rigid brake pipes for a. fouling by a moving part a. fouled by moving parts b. kinks b. kinked c. chafing, corrosion and damage Note: To assess correctly the condition of corroded metal pipes, surface dirt might have to be removed. This might require light scraping with the Corrosion Assessment Tool ‘spade end’. Care must be taken not to damage any protective coating.
c. excessively chafed, corroded or damaged
Note: Chafing, corrosion of, or damage to, a rigid brake pipe so that its wall thickness is reduced by 1/3 (eg approximately 0.25mm for typical hydraulic brake pipe) is a reason for rejection d. repairs
d. inadequately repaired or with unsuitable joint fittings
Note: Repairs to the pressure lines of hydraulic brake systems are unacceptable unless suitable connectors are used. Compression joints of a type using separate ferrules are not suitable 3. Examine flexible hoses for signs of weakness under pressure with foot-brake fully applied. 3. A flexible hose bulging under pressure. 4. Examine all flexible hoses for 4. A flexible hose a. room to move as necessary without fouling any part of vehicle a. has insufficient room to move, resulting in fouling on any part b. kinks b. kinked c. stretching or twisting c. stretched or twisted
d. chafing or deterioration
Note: A hose should be rejected for cracking or chafing only if that is sever enough to expose the reinforcement. d. excessively chafed or deteriorated e. exposure to excessive heat e. exposed to excessive heat
No mention of copper being illegal. Please stop the misinformation. They may be not as good as the other forms of pipe but certainly not illegal.
Posted 18 December 2011 - 10:47 PM
In which case, you could use elastic bands for tyres. It doesn't mention anything about those either.Taken from the MOT manual.
As posted above, copped simply isn't fit for purpose.
Posted 18 December 2011 - 10:56 PM
Posted 18 December 2011 - 10:58 PM
At the end of the day, anything used in a safety-critical application is either suitable or unsuitable. If it is unsauitable and not fit for purpose, it is covered by product liability laws, amongst other things. It does not specifically have to be listed in the VOSA rules for that to be so.
I think minimissionary makes that point rather well.
Posted 18 December 2011 - 11:03 PM
You have no way of knowing whether the fatigue fracture was caused by vibration, or by pressure cycling. Most likely, both contributed to the failure. Even if you clip the copper down tightly (not leaving it floating in mid-air as an alleged mechanic here is advocating), the pressure cycles as the brakes are periodically applied will make it suffer fatigue failure in exactly the same way.
Posted 18 December 2011 - 11:09 PM
