Gianni Potenza Wheels: Cheaper Version...
85 replies to this topic
#16 1977 Loud_Mini
1977 Loud_Mini
  • 896 posts
Posted 23 December 2011 - 10:26 PM
I have seen these wheels used on someones car, it may have been on Turbo minis as mentioned already and i don't think they had any problems running them. It was an orange/red mini. I was going to get a set of these for my mini before i decided to go down the rally inspired route.
Evan.
Edited by 1977 Loud_Mini, 23 December 2011 - 10:27 PM.
#17 Driezzie
Driezzie
  • 662 posts
Posted 23 December 2011 - 11:11 PM
Someone of mini mania maybe ? Markus, the owner of the grey mini in this thread, also told me this.
#18 Driezzie
Driezzie
  • 662 posts
Posted 26 December 2011 - 10:15 AM
Got this email from Minisport.
Hi
Thanks for your email the sportspack wheels have a load rate of 300kg each
The minilites do not have a rating on them.
Kind Regards
300 kg = 661 lbs
Edited by Driezzie, 26 December 2011 - 10:22 AM.
#19 Shifty
Shifty
    Sponsored by Fosters (tm)
  • 13,139 posts
  • Name: Sean
Posted 26 December 2011 - 10:21 AM
300kg doesn't sound a lot?
A sports pack weighs a bit over 700kg on its own, add to that the forces involved when cornering I'm sure that figure should be higher?
#20 Driezzie
Driezzie
  • 662 posts
Posted 26 December 2011 - 10:24 AM
Mini Classic MPI
approx unladen weight (full fuel tank excluding options) : 715 kg / 1576 lb
maximum gross vehicle weight : 1050 kg / 2315 lb
each wheel so
4x 300 kg = 1200 kg
4x 661 lbs = 2644 lbs
Edited by Driezzie, 26 December 2011 - 10:26 AM.
#21 Shifty
Shifty
  • 13,139 posts
  • Name: Sean
Posted 26 December 2011 - 10:29 AM
Isn't that what I said??
Have a look here..
http://www.theminifo... wheels__st__15
What happens when the car corners and the loading on that wheel increases?
#22 Driezzie
Driezzie
  • 662 posts
Posted 26 December 2011 - 10:42 AM
Hmm you're right. I've send another e-mail for confirmation to them.
#23 Driezzie
Driezzie
  • 662 posts
Posted 27 December 2011 - 09:55 AM
On another forum someone says his superlights have a max load rate of 250 kg, someone who can confirm this ?
Also found this on the website of superlite, apparently they also produce ATV/go cart wheels !
http://www.superlite...om/atvquad.html
Edited by Driezzie, 27 December 2011 - 09:58 AM.
#24 conlad
conlad
    Previously known as ct16mini.
  • 2,054 posts
  • Local Club: Hilltop Minis
Posted 27 December 2011 - 10:02 AM
But what is the weight they can take? A quad which weighs something like 350-450 KG is a lot different to a mini of say, mininum 750KG, then they wont be manufactured to hold that type of weight and strain, because the speeds are higher in a car than a quad - and then again you factor in forces acting at higher speeds...
Bla bla blaaaa... :ermm:
#25 Driezzie
Driezzie
  • 662 posts
Posted 27 December 2011 - 10:08 AM
I've also send an e-mail to them now.
Edited by Driezzie, 27 December 2011 - 10:09 AM.
#26 Shifty
Shifty
  • 13,139 posts
  • Name: Sean
Posted 27 December 2011 - 10:11 AM
And???
A wheel company that makes(or just sells) wheel for other applications isn't a big discovery?
Give them a ring and ask if they recommend using their ATV/go cart wheels on your mini.
I'll bet I know what they say.
#27 Driezzie
Driezzie
  • 662 posts
Posted 28 December 2011 - 10:31 AM
Got a reply from minisport about the sportspack wheels.
Hi
This is correct as 300kg per wheel so x 4 is 1200kg.
Rob
Edited by Driezzie, 28 December 2011 - 10:31 AM.
#28 Shifty
Shifty
  • 13,139 posts
  • Name: Sean
Posted 28 December 2011 - 10:37 AM
Its entirely up to you if you fit them, I know that I wouldn't, I also know that this idea has been discussed and dismissed several times over the last few year.
If you want to fit them then I can't stop you, I don't think that they are safe, people who are cleverer than me don't think that they are safe.
#29 conlad
conlad
  • 2,054 posts
Posted 28 December 2011 - 11:19 AM
Well its simple aint it really...
Golf cart wheels ---> 700/800+ KG mini
would be like saying..
Minilight wheels ---> Landy discovery which is 2+ tonne
Hmmmmmmmmmmmmmmmmmmm...
Edited by ct16mini, 28 December 2011 - 11:19 AM.
#30 Driezzie
Driezzie
  • 662 posts
Posted 28 December 2011 - 11:24 AM
so called golf cart wheels on a mini classic powered by a suzuki engine. (yes it's a work in progress.)
They look a lot (if not the same) like potenzas.
