Project Cliff - The Cherry Red Thirty
#106
Posted 24 January 2012 - 10:41 PM
#107
Posted 25 January 2012 - 07:55 PM
can i ask whats the red jet conversion do? i may sound stupid :L but ive never heard of it before xD
no worries mate...the red jet conversion is to replace the wax stat on the bottom of the carb.
as the name suggests, the wax stat contains a small piece of wax that melts when the engine warms up, this causes the needle to move and lean off the fuel to the carb and thus giving better fuel consumption.
the red jet conversion is just a fixed version of the wax stat so it can be set up much easier on a rolling road and allows for easier tuning of the engine but it decreases fuel efficiency slightly.
i got this from min-its but it is available from mini spares and mini sport although the mini spares product does not come with the little bracket required but it can be brought separately.
http://min-its.com/m...ries/HS2_4.html
http://www.minisport...fo_AUE1111.html
plus the red jet conversion is cheaper than a new wax stat as mine was broken and bodged (the pipe had snapped and been forced on so it was leaking slightly and a leaky fuel pipe is bad directly above the exhaust manifold
hope this clears it up for you
Rhys
#108
Posted 25 January 2012 - 08:15 PM
i think you can get it but just not from mini spares...mini spares do a linkage set but i don't think it contains the little bracket needed
Rhys
Edited by TH3aRchit3ct95, 25 January 2012 - 08:20 PM.
#109
Posted 26 January 2012 - 10:11 AM
#110
Posted 26 January 2012 - 07:08 PM
my dad has been steadily working on my doors at work this week and i'm getting some primer on my boot, bonnet and doors this week end (as long as the rain holds off
i'm going to Bingley hall Sunday so i'll post up some pics of the goodies i pick up, my shopping list is:
- front panel
- wings
- A panels
- lower rear quarter repair panels
- front rear subframe mounts
- standard special arch and sill kit
and anything else that takes my fancy whilst i'm there
oh, i got this the other day...
battery cut off switch
so that's it for now any way
Cheers for the interest in my project, it's nice to have encouraging feedback from others
Rhys
#111
Posted 26 January 2012 - 09:41 PM
keep up the good work
Leon
#112
Posted 27 January 2012 - 06:54 PM
looks like cliff is getting spoilt
Leon
there are more shiny new parts where that came from
tomorrow i'll dig out the speakers system i've got planned for him and i will definitely be buying parts from Bingley hall
Rhys
#113
Posted 28 January 2012 - 05:19 PM
two 8" x 6"
two 2.5" (i made these at sixth form in product design)
there will also be the original parcel shelf speakers and any others i find along the way
i'm not aiming for an out and out ICE system but i want a subtle speaker system with each speaker (other than the two originals on the parcel shelf) hidden from view.
Rhys
Edited by TH3aRchit3ct95, 28 January 2012 - 05:22 PM.
#114
Posted 28 January 2012 - 06:01 PM
primed boot lid...
primed bonnet...
primed wing mirrors...
primed number plate light housing...
i also stamped my engine number plate today...i brought two plates, in case i got it wrong the first time, but i did it the first time so i stamped my own name into the second one so i now have a personalised engine number plate
i might see some of you tomorrow at Bingley... yeah, i can't wait to go spend some money on things i don't really need
Rhys
#115
Posted 28 January 2012 - 06:07 PM
#116
Posted 28 January 2012 - 06:27 PM
is it because restoring him is an uphill struggle?!?
good luck with the resto matey! top job
#117
Posted 28 January 2012 - 06:34 PM
why is it called cliff??
is it because restoring him is an uphill struggle?!?![]()
il get me coat...
when i got him, i was looking through the log book and the owner had written CLIFF on the inside of the front cover...and the name stuck...
but i think i'll go with your explanation...
#118
Posted 29 January 2012 - 06:40 PM
three wire brush grinder attachments
alloy heated inlet manifold ( £10 ! ! )
standard front subframe rear mounts
rear subframe mounting bolt kit
metro front door pockets with speaker pods and speakers (unfortunately one speaker is torn and i haven't tested the other yet but i will probably get some uprated 4 inch speakers as these seam to be pretty cheap and nasty)
2 inch, single box, centre exit exhaust system with 3-2-1 LCB manifold
i got all of this for less than the price of a new LCB ! ! not a bad days work if i do say so my self
i didn't get any panels as we left the panel buying until last to find that they had sold out of the ones i needed (mk4 front panel, A panels, wings with side repeaters and aerial hole, and a lower rear quarter repair panel) oh well...Ebay, here i come
Rhys
#119
Posted 29 January 2012 - 08:19 PM
#120
Posted 29 January 2012 - 08:33 PM
Cliff is going to be one mint mini 30, its a good thing he fell into the right hands.
Best of luck with the rest of the project, I will be watching to the finish!
Bing (1)
