boot painted in the same paint as the under side
this paint will also be used for the engine bay later this week
all panels lined up and doors put in place to check gaps
bonnet gaps are nearly perfect
we were going to clamp all the panels together and remove them to weld up all the seams but the gaps were so good we decided to weld it in situ
all done
O/S inner wing
N/S inner wing
for pattern panels, the alignment and shape is spot on
O/S wing to front panel seam
N/S wing to front panel seam
O/S scuttle to wing seam
N/S scuttle to wing seam
