we then seam sealed the welds
and primed and stone chipped from the heel board back
i then had a poke around the sill with a screw driver...
...how this got through the last MOT i will never know
...we were lucky to drive this the two hours home without it falling apart
so we got to work cutting out the last of the rusty metal ( hopefully ) and you will be surprised to know that this side isn't as bad as the other...how ?
new subframe mount repair fitted
2mm thick angle iron to repair and reinforce the base of the companion bin and rear inner sill ( the same as we did to the other side )
then we made a panel to repair the rest of the inner sill ( apart from the front floor pan )
then we gave the new metal and welds a clean up and a coat of etch primer
before we packed away for the night, we gave the door step, jacking point and any other areas of remaining rust a coat of rust reverter
tomorrow we will fit the new front floor panel, fit the outer sill, repair the flitch panel, fit the other scuttle closure and then maybe fit the new scuttle and...well...we'll see what happens
Rhys
Edited by TH3aRchit3ct95, 01 March 2012 - 09:03 PM.
