Car With Gripper Type Lsd Is Quite Hard To Push Is This Normal Please Zcars Steve?
5 replies to this topic
#1 Alburglar
Alburglar
    Das Pingu's
  • 3,331 posts
Posted 16 December 2011 - 12:42 AM
FAO Zcars
or anyone else for that matter,
My car is harder to push than I expected. With no apparent brake binding issues I am suspecting the diff. Would the gripper type LSD be harder to push around than a standard type diff?
It appears to drive ok, but it hasn't exactly been put through it's paces yet.
...or am I just weak as a kitten?
#2 Guess-Works.com
Guess-Works.com
    Gearbox Guru
  • 19,838 posts
Posted 16 December 2011 - 07:49 AM
depends if you're trying to push it round a corner...
#3 cptkirk
cptkirk
  • 1,799 posts
  • Local Club: B.M.C. + Chiminiclub
Posted 16 December 2011 - 08:42 AM
Hey Alburglar
The gripper diff makes the car very hard to push around corners, before swapping mine for a Quaife I could hear the gripper diff grawnching as you tried to push it round a corner. The whole diff things is discussed here if you wanted more on it::::::http://www.theminifo...ic=139772&st=45
Its a horses for courses thing really, if you want an agressive diff that will allow you to snap a driveshaft but it will still propel you using only one or if lifting the inside wheel is of concern then a gripper or any plate type is a good option.
#4 Alburglar
Alburglar
    Das Pingu's
  • 3,331 posts
Posted 17 December 2011 - 02:07 AM
Thanks for that. As long as it's not broken I'm happy. I remember pushing a mini with a salisbury diff that was a pig, so I had an incling that might be the case.
...and sheernes is only 40 minutes away from me if I do fancy the ATB!
#5 Alburglar
Alburglar
    Das Pingu's
  • 3,331 posts
Posted 17 December 2011 - 02:19 AM
...shame it is the a-hole of kent tho...
#6 Carlos W
Carlos W
  • 10,114 posts
Posted 17 December 2011 - 08:19 AM
Agree
