Master Cylinder Primary Piston Stuck
8 replies to this topic
#1 rawky
rawky
  • 419 posts
Posted 14 December 2011 - 06:41 PM
Hello,
I am rebuilding my master cylinder, and after removing the circlip and the washer and the first internal seal the piston still won't come out! I have tapped it on wood and tried to pull it with pliers but with no luck!
What could be holding it in?
Many Thanks
#2 rawky
rawky
  • 419 posts
Posted 14 December 2011 - 09:25 PM
BUMP
#3 Brams96
Brams96
  • 2,308 posts
Posted 14 December 2011 - 11:08 PM
Which type is it? This one Posted Image or this one Posted Image ??
#4 rawky
rawky
  • 419 posts
Posted 15 December 2011 - 07:30 AM
Second, but mine lies flat in the engine bay. Have I just not disconnected something?
#5 grahama
grahama
  • 2,442 posts
Posted 15 December 2011 - 08:28 AM
Hi,
this is what is inside
It is probably that you have some gunk in there making the seals tight, keep knocking it carefully and easing it out with a screwdriver and it should come eventually. There are no more clips or bolts stopping it !! Take the seals out from under the resevoir bottle to prevent any vacums forming, may help.
Graham
Edited by grahama, 15 December 2011 - 08:30 AM.
#6 Brams96
Brams96
  • 2,308 posts
Posted 15 December 2011 - 02:11 PM
Is your like this Posted Image with the servo assist?
#7 Ethel
  • 25,831 posts
Posted 15 December 2011 - 02:59 PM
Never had one of those to bits but many tandem cylinders have a pin that is accessed by removing the reservoir
#8 rawky
rawky
  • 419 posts
Posted 15 December 2011 - 06:34 PM
Yes
Yes I have removed that pin, it holds in the secondary piston!
#9 rawky
rawky
  • 419 posts
Posted 15 December 2011 - 07:43 PM
Fixed! Just took a tap with a hammer eventually. The initial, wider part of the bore had a bit of surface corrosion which I think was holding it in!
