Birdmans Monte Carlo Build
384 replies to this topic
#316 cptkirk
cptkirk
  • 1,799 posts
  • Local Club: B.M.C. + Chiminiclub
Posted 17 July 2013 - 10:52 AM
I also have been talking with Chris at Z-Cars about a new shifter.  They use the one called "FlatShift".  They just use the ignition cutout with the mnual lever.  But I want to use my buttons.
There is a company in America, Rilltech Racing that carry's the Flatshifter so I have one coming from them.  I am getting the "Pro" with throttle blipper for clutch less up shfts and down shifts via paddles or steering wheel buttons.  This was shipped today so I should get it maybe friday.
That sounds like it will be a super sweet setup once its all together, looking forward to hearing how it all works out as this would really suit my future sprint car design.
#317 Birdman
Birdman
  • 400 posts
Posted 17 July 2013 - 12:24 PM
I'll let you know.
#318 Birdman
Birdman
  • 400 posts
Posted 21 July 2013 - 03:27 AM
I started installing my new "Flat Shifter" today.  The paddles are a bit short so I have ordered the option 1" longer ones.
  • Attached File  155.jpg   49.35K   36 downloads
  • Attached File  156.jpg   39.08K   28 downloads
  • Attached File  157.jpg   36.69K   26 downloads
#319 Birdman
Birdman
  • 400 posts
Posted 08 August 2013 - 11:43 AM
I started installing my new dry sump oil system yesterday. Mike Downs of Downs Engineering made it  He normally mounts the pump in front of the engine but this wouldn't work for mr because of a frame rail in the way where the belt drive would go.  So he made a different mount kind of behind the motor with the pump facing outward.  I still had to modify the oil pump mount quite a bit because of the frame rail in the way.  (circled)  But got it to fit.
Next I'll finish hooking everything up to the engine, then install the oil tank and start running all the hoses.
  • Attached File  163.jpg   57.22K   43 downloads
  • Attached File  162.jpg   68.23K   41 downloads
  • Attached File  161.jpg   70.22K   42 downloads
  • Attached File  159.jpg   70.79K   44 downloads
  • Attached File  158.jpg   62.26K   55 downloads
#320 Birdman
Birdman
  • 400 posts
Posted 09 August 2013 - 02:26 AM
I finished the dry sump installation today.  this is what 500 bucks worth of Russell hose and fittings looks like.  I had to put a 90 degree fitting in the pan outlet as the straight fitting hit my frame rail.  (Dam frame keeps getting in the way).  But outside of that everything was pretty straight forward.
  • Attached File  166.jpg   64.54K   44 downloads
  • Attached File  165.jpg   62.84K   45 downloads
  • Attached File  164.jpg   61.44K   39 downloads
#321 Birdman
Birdman
  • 400 posts
Posted 10 August 2013 - 03:33 AM
It's all together, up and running.  Raining to hard for a test drive though.
#322 StefanPieter
StefanPieter
  • 131 posts
  • Local Club: FDMC
Posted 12 August 2013 - 08:42 AM
Well done on the install Birdman.
It looks good. What oil are you using?
#323 Birdman
Birdman
  • 400 posts
Posted 12 August 2013 - 01:12 PM
Castrol 20/50 full synthetic motorcycle racing oil.
#324 Birdman
Birdman
  • 400 posts
Posted 18 August 2013 - 01:19 PM
The new dry sump system is up and running.  I've been driving the car around the neighbor hood and so far so good.  This afternoon we're heading to ORP for a track day tomorrow, wiish me luck.
#325 Birdman
Birdman
  • 400 posts
Posted 21 August 2013 - 01:50 AM
I took the Minibusa out for a few test laps yesterday.  WOW!  I was amazed at the difference the wing made.  I didn't have enough time to really play with it but every corner felt much better, the two hills I have lifted in the past I can now take full throttle, the slicks showed more signs of wear, and all in all the car just felt better and more solidly planted than it's ever has.
#326 cptkirk
cptkirk
  • 1,799 posts
Posted 23 August 2013 - 06:53 AM
Great News - I might need to look at a removable aero package for mine.....
#327 Birdman
Birdman
  • 400 posts
Posted 12 September 2013 - 09:31 AM
I'm back at finishing the paddle shift install.  I had added the paddles to the steering wheel but that was as far as I got.  So the last couple of days I installed all the rest of the goodies.  Up shifts are working perfectly but I can't get enough vacum to run the throttle blipper for down shifts.  I'll be working on that today.
#328 RemKingston
RemKingston
  • 112 posts
  • Local Club: Essex Mini Club
Posted 12 September 2013 - 05:39 PM
Beautiful work! Amazing Birdman!
#329 Birdman
Birdman
  • 400 posts
Posted 12 September 2013 - 07:29 PM
I had to install a new tap for the vacuum line feeding the blipper.  All is now good and working like a charm.
Now I just have to learn how to run my darn camera so I can get some videos Monday.
#330 cptkirk
cptkirk
  • 1,799 posts
Posted 13 September 2013 - 01:49 PM
Looking forward to those videos.......
