Birdmans Monte Carlo Build
384 replies to this topic
#166 Birdman
Birdman
  • 400 posts
Posted 26 March 2012 - 10:48 AM
Yes it is installed, it's the one from Z-cars and total travel from idle to wide open is 4 inches.
#167 Monte Busa
Monte Busa
  • 681 posts
Posted 26 March 2012 - 01:54 PM
Is that pedal movement or cable movement? ...sounds like pedal movement, yes? if it's not too much trouble, I need cable movement just in case our linkages have different ratio at the pedal.
#168 Birdman
Birdman
  • 400 posts
Posted 27 March 2012 - 01:04 AM
Yes that was pedal movement. Cable travel is exactly 1 inch.
#169 Monte Busa
Monte Busa
  • 681 posts
Posted 27 March 2012 - 03:01 AM
Awesome, thanks!!
#170 Birdman
Birdman
  • 400 posts
Posted 28 March 2012 - 11:26 AM
Well this is getting pretty frustrating. When Z-Cars sent my kit they sent the wrong wheels, wrong offset. So I have been waiting 2 months for the correct wheels to come. They came yesterday and guess what. The back wheels still hit the swing arms, not much, but they do rub enough to be not acceptable. So I'm going to have to rework my swing arms, cur a notch and re weld to give me the clearance I need.
To further complicate things the wet slicks I got are two big, the Avon dry slicks fit with in the fender openings just fine but the wet Avon's are bigger and hit the body. So they will have to be replaced.
And the tire shop that mounted my tires yesterday put some of the wheel weights on the rim and they are hitting the swing arm and will have to come off, and the wheels re-balanced.
Just some more glitches in this never ending saga.
#171 edsmini
edsmini
  • 357 posts
Posted 28 March 2012 - 01:01 PM
would hubcentric spacers not work? i would say that is a better option than chopping the rear arms.
Ed
#172 cptkirk
cptkirk
  • 1,799 posts
  • Local Club: B.M.C. + Chiminiclub
Posted 28 March 2012 - 02:13 PM
As a person thats been through a Zcars build I can confidently say that a 'never ending saga' is a very good way of putting it.......
I have said before in other posts that a Zcars build is not a regular kit car build, theres a certain amount of fettling that is required and once you've bought the kit there's so so much more you need to fabricate/alter/buy to finish the build, thats if what you've been sent in the first place is the right stuff. I will openly admint to points in time during the build I wanted to sell it/burn it/cut it up into little peices but you get through all that and its worth it in the end.
#173 Birdman
Birdman
  • 400 posts
Posted 28 March 2012 - 02:22 PM
All in all I think Z-cars quality is outstanding. But their customer service sucks. I have built many a car before and am well aware of the "Tinkering" that needs to be done as the build goes along. But I think supplying wheels that won't fir is a bit out of question.
Now I can't add spacers, which would be easy. Because the wheel studs in the hubs are just barley long enough as it is. Adding spacers would not give me enough threads for the lug nuts. Longer studs could be added but I would have to tear the whole rear susp. apart to get the studs out. There's not enough room to pound them out and replace them. Part of the bearing housing is in the way. So I'll just notch the trailing arms a bit, 1/4 inch will be enough.
#174 edsmini
edsmini
  • 357 posts
Posted 28 March 2012 - 02:28 PM
sounds like a plan, it can be the simplest things that cause the biggest headaches, and the problem yuou have is that every part you order from Zcars takes weeks to reach you (very frustrating), however, hang in there birdman, you will get there, my current project is eating the hours and £££££ or $$$$ in your case.
Ed
#175 Birdman
Birdman
  • 400 posts
Posted 29 March 2012 - 12:11 PM
I notched the trailing arms so mow I have a good 3/8 inch of tire clearance.
I'm taking the body to my painter today. Just going to be white. I'm hoping to get it back Sat but time will tell.
  • Attached File  54.jpg   42.44K   89 downloads
#176 edsmini
edsmini
  • 357 posts
Posted 29 March 2012 - 05:02 PM
just the job, its like it was meant to be that way .
Ed
#177 Birdman
Birdman
  • 400 posts
Posted 29 March 2012 - 07:56 PM
Ed
Thanks Ed
#178 Birdman
Birdman
  • 400 posts
Posted 29 March 2012 - 07:59 PM
Well I did it. Took theMonte Carlo down the road. Steers straight, brakes straight, motor ran fine. All I can say is when the turbo kicks in you better be hanging on. I AM IMPRESSED!
Only one problem, no body, no aluminum interior, and a gravel driveway. BG!
  • Attached File  55.jpg   74.08K   135 downloads
#179 cptkirk
cptkirk
  • 1,799 posts
Posted 30 March 2012 - 07:21 AM
WHOOPS.....
Looks like you got a bit of cleaning to do.
#180 Birdman
Birdman
  • 400 posts
Posted 30 March 2012 - 10:32 AM
WHOOPS.....
That's what shop vac's are for. BG
