Birdmans Monte Carlo Build
#136
Posted 17 February 2012 - 03:45 AM
#137
Posted 17 February 2012 - 05:57 PM
I find that quite odd, as you will no have no camber gain in roll, and contact patch variation will be quite large - especially with 10" wide tires! Non semi-trialing arms work on FWD minis quite well as camber gain actually fights any oversteer tendency you'd want to have in a naturally understeering configuration, but in a rear drive car you'd be potentially inducing a lot of oversteer-causing characteristics and contact patch variation that could be pucker causing.
Also, you might want to check what sort of bump steer you have with the steering rack configured the way it is. I found I had to run a tapered washer to get the steering rack arms anything like parallel to the top A Arm and dial out bump steer.
#138
Posted 17 February 2012 - 07:07 PM
#139
Posted 18 February 2012 - 01:21 AM
#140
Posted 18 February 2012 - 03:00 AM
With this arrangement (which my car and the previous Montes I've seen have) you get negative camber GAIN in roll (negative camber increases with an increase in body roll), which is important for lateral traction in high G situations in keeping a consistent contact patch. Another benefit of angling the mounting points as described is that you get a lower roll center, as the arm pivot axis intersects the wheel axis which is one of the cons of trailing arm suspension with no semi-trail characteristic - the roll center is the height of the pivot, period.
It's puzzling that they removed the semi-trailing feature on your car...maybe they found something with the handling characteristics of the car recently...I may e-mail Chris to discuss. I'll let you know what he says.
Maybe the picture dos not show it that well but there are trailing arms that are fully adjustable. I'll check the bump steer when I get the car at the correct ride height. Thanks for the tips.
Edited by Monte Busa, 18 February 2012 - 03:02 AM.
#141
Posted 18 February 2012 - 12:00 PM
#142
Posted 18 February 2012 - 01:09 PM
#143
Posted 23 February 2012 - 02:59 PM
My tank and pedals are here so I can go back to work on the new car.
Posted 26 February 2012 - 05:22 AM
I'm pretty much at a stand still now waiting to get the car in the paint shop.
Posted 27 February 2012 - 12:50 AM
Aric
#146
Posted 27 February 2012 - 01:11 PM
Lookin' good! Do you mind me asking a favor? Could you tell me what the fully extended length of your front shocks is? Also, the free length of your front springs? It would be awesome if you could throw a tape on them and let me know.
Aric
Will do.
#147
Posted 28 February 2012 - 05:16 PM
Aric
The front shocks are 15". the springs with all weight off are 8".
#148
Posted 28 February 2012 - 09:21 PM
Awesome, thanks! By the way, I e-mailed with one of Chris' guys (also Chris) about the rear geometry changes. He confirmed that they did reduce the cross car semi-trailing angle on the cars later than mine at some point, to decrease camber gain on bump - likely to increase tire footprint on straight line acceleration when running without anti-roll bars. I personally prefer the setup of my car on paper at least, with -0.7deg camber gain with 1" of bump on the rear as it closely matches the front gain (-1.0deg per 1" of bump), but if you're going to run anti-roll bars it's probably a moot point as the roll rate will be quite low (probably 0.2 to 0.4deg per 1G lateral).
By the way, are you runnng bars? If so, and you don't have them yet (I haven't seen any in your pics), I am considering upgrading to cockpit adjustables and would sell you mine if you were interested if I decide to go that route. The front one will fit your car with no mods, and the rear will fit with just a simple change in the position of the lateral location collars.
Edited by Monte Busa, 28 February 2012 - 09:22 PM.
#149
Posted 29 February 2012 - 02:22 AM
#150
Posted 29 February 2012 - 04:43 AM
I didn't get any with my kit. To be honest it's something I hadn't given any thought to. I might be interested in yours. Can you give me a call sometime? 541-408-3317.
