7 Port Head Out Of A 5 Port?
cradley-heathen
, Dec 07 2011 06:40 PM
11 replies to this topic
Posted 07 December 2011 - 06:40 PM
i have tried searching on here for a thread which had pics of a 5 port head that had been hugely moddified into a 7 port.
can someone point me in the direction of it please? its really bugging me!
Posted 07 December 2011 - 06:49 PM
There where some pictures up a while ago of a head that had been modified so that the inlets ports went through the rocker cover and straight down to the top of the inlet valves but I've never seen a 5 port head turned into a 7.
Posted 07 December 2011 - 06:57 PM
that sounds like what im talking about, didnt it have 4 ports across the front though? i thought there were 4 tubes fitted into the head, one going to each of the inlet valves, making it a 7 port?
Posted 07 December 2011 - 08:14 PM
This is a Manx 7-port
http://mk1-forum.net/viewtopic.php?f=7&t=3421&p=24170&hilit=manx#p24170
although the one I have had in my hands just had enormouse inlet ports to enable the inlet manifold to fit, rather than a true 7-port.
I have been told that some 7-port Manx heads did have split ports, but I'm not sure it's true.
There is also the Speedwell 7-port (but this is based on a smallport casting)
Posted 07 December 2011 - 08:24 PM
it definately had the ports on the front, poking up at something like 45degrees, through the rocker cover
what are the inlet ports on that manx like then?
Posted 07 December 2011 - 10:00 PM
I used to have some pics of the head inlets of one of these but lost them in a HD incident
the manifold has a square "stub" that fits into the head, also the ports are very high, and they are indeed split in a similar way to the speedwell head above.
Posted 08 December 2011 - 08:47 PM
oh bum! i think im going to have to reside myself to not finding this!
i have spent hours on google now tryting to find the one im talking about,
it was defianately a modified 5 port head, that had steel tubes inserted down the machined holes.
someone else on here bought up the issue of how would you "fix" the steel tubes to the cast iron head?
and someone else mentioned using some kind of modern resin type goop like they use to bond morgan aluminium chassis together etc.
please someone say this is ringing a bell?
Posted 08 December 2011 - 09:13 PM
normally mods like this are Brazed,
interestingly, I have glued up my exhaust ports where I broke through into the push rod holes, apparently used the same stuff they stick the tiles to the space shuttle...
Posted 08 December 2011 - 09:20 PM
i did wonder if they were brazed, one thing is for sure they aint mig'd!
Posted 08 December 2011 - 09:26 PM
Is this what your thinking of?
Head_011.JPG 112.02K
58 downloads
Head_021.JPG 97.6K
39 downloads
Or this...
Because they all only have 5 ports
Or this...
Posted 24 November 2012 - 12:50 AM
really late but just seen this look at 7 ports myself is this the one >
Posted 24 November 2012 - 02:35 AM
