Sub Under The Seat?
Posted 07 December 2011 - 01:06 PM
Pretty simple i'm sure, but i've had no luck finding them on a google search.
Basically, i am after a subwoofer that i can fit under the rear seat, but i can't find them small enough! I don't want it in the boot, nor do i want to remove the rear seat, so it does need to be quite precise!
Anybody had any luck with this?
Posted 07 December 2011 - 01:14 PM
http://www.play.com/Electronics/Electronics/-/3215/2482/-/17847461/Kenwood-KSC-SW01-Active-8-Inch-Underseat-Subwoofer/Product.html?mckv=mkwid|smygYUOh2|pcrid|10851560671|plid||kword|&_$ja=kw:_cat%3aelectronics|cgn:_cat%3aelectronics|cgid:2062185391|tsid:11747|cn:play.com_Keywordless|cid:57655831|lid:24269358871|mt:Broad|nw:search|crid:10851560671|bku:1&gclid=CO2Dif2E8KwCFZQhtAod60O2MQ
Posted 07 December 2011 - 01:31 PM
Loads of Active units here, just click through the pages there has got to be at least 20 options.
http://www.caraudiod...earchSortBy=PLH
But I don't think anything on the market will fit JUST under the rear seat i think they will protrude a little way out.
Best look at the specs and have a measure up.
Posted 07 December 2011 - 02:03 PM
http://www.europe-au...Product_ID=5677
Tymphany is one of the best speaker manufacturers in the world so its not cheap and you will need a separate amp to power it.
It would look awesome though.
Posted 09 December 2011 - 02:02 PM
Posted 09 December 2011 - 07:37 PM
What i am after is a sub small enough to fit in a purpose made "box" under the REAR seat, that would look something similar to having a speaker board down there, if that makes sense?
With that, i would then try and mount a couple of small speakers in place of the air vents in my dash plus the 6x9's on the parcel shelf (the holes were already there, crudely cut!)
Posted 09 December 2011 - 08:41 PM
Small speakers in the air vents is fine aslong as the sub can produce low enough for your needs. ideally you should get comps at the front (tweets above the dash).
Drop the 6x9's and cover the holes!. - spend the money you have saved on the other kit you mention.
When you build the enclosure you want to make it nice and sturdy - with enough capacity for the planned sub.
Do you want to run two subs (one each side) or just the one?
http://www.tb-speaker.com/ - these make some good quality, reasonable priced subs that will fit - i believe you can go for 6.5" or 6x9 subwoofers - but dont quote me on that - measure before buying to check
Posted 09 December 2011 - 10:14 PM
What's the budget and what amp are you using?
Edited by Ruckus, 09 December 2011 - 10:14 PM.
Posted 15 December 2011 - 12:09 AM
you need to measure the distance/clearance you have, then look at the size of sub and allow some extra room for the sub to flex
Posted 15 December 2011 - 07:11 AM
The best shallow subs out there are the Phase Linear Aliante 10, and 12", and they can be used 'Free Air'. So a small open sided mounting can be used.
Posted 16 December 2011 - 10:32 AM
Hadn't thought about using a sub face up.
never really looked into phase so i wouldnt know, but end of the day, may have to do your research in2 size vs sound quality sub wise as im pretty sure there isnt as much space under a mini seat compared to that of modern day cars which have them as standard
Posted 16 December 2011 - 12:00 PM
Posted 07 January 2020 - 12:35 AM
I didn't want to take up boot space with a sub either.
I made an under seat speaker board
http://www.minifinit...peakerboard.pdf
And installed two 6" sub's.
The volume of space under the rear seat met the air volume requirements of the subs
I have 6" mids on the back shelf and in the doors https://absmotorspor...er-pocket-pair/
I mounted my tweets near the top forward corner of the door card. They came with an angled collar so I could point them inward a bit
I have my main amp in the boot against the back seat (mids and tweets). I have an amp for the subs mounted in the boot on the underside of the rear shelf
I put my crossovers on the backside of the board that the subs are mounted too
It all works pretty good
