Do I Need A Crank Regrind?
15 replies to this topic
#1 andymini12
andymini12
  • 812 posts
Posted 06 December 2011 - 08:07 PM
Hi
I have stripped my 998 engine down and got the crank out, it does not seem to be in that bad condition.
I have read about people not regrinding there crank if it is alright condition can you do this?
Im thinking to get it reground anyway as it seems a thing not to miss in a engine rebuild.
Also how much should a crank regrind be?
Attached File  IMG00599-20111206-1949.jpg   165.31K   21 downloads
Attached File  IMG00601-20111206-1958.jpg   194.6K   19 downloads]Attached File  IMG00602-20111206-1958.jpg   132.68K   15 downloads
Attached File  IMG00597-20111206-1949.jpg   156.97K   13 downloads
Thanks Andy
#2 zef
zef
  • 223 posts
Posted 06 December 2011 - 08:14 PM
Well the pic's aren't perfect but on the basis of what I can see I'd just reshell it and use it.
Edited by zef, 06 December 2011 - 08:15 PM.
#3 Artful Dodger
Artful Dodger
    " I AM THE SPECIAL ONE"
  • 4,435 posts
Posted 06 December 2011 - 08:20 PM
see about getting it polished. gets rid of all of the tiny engravings in the crank bout hardly reduce the size.
#4 Frisco
Frisco
  • 414 posts
Posted 06 December 2011 - 08:21 PM
Run your finger nail across the journals and if it gets cought on anything the crank needs a regrind. If it seems good after that get some plastigauge and check the tolerences.
Its cheap to do.
#5 andymini12
andymini12
  • 812 posts
Posted 06 December 2011 - 08:29 PM
I have already run my finger nail over all of the journals and it does not get caught on anything.
What is plastigauge?
Thanks Andy
#6 mini-luke
mini-luke
    Postman Pat
  • 2,362 posts
Posted 06 December 2011 - 08:32 PM
They are clever gauges that when crushed in the journal will give an indication of the clearances.
#7 racingbob
racingbob
  • 3,061 posts
Posted 06 December 2011 - 08:57 PM
get it professionaly checked mine looked not to bad but it did need a grind when
when saunders engineering checked it out
#8 andymini12
andymini12
  • 812 posts
Posted 06 December 2011 - 09:12 PM
Yeah i think i will,
How much will a crank regrind be?
Also i have heard good things about dartford rebore, so i am thinking of taking it there?
Andy
#9 R1minimagic
R1minimagic
  • 4,660 posts
Posted 06 December 2011 - 09:13 PM
Why dont you measure the journals and see if they are still in spec?
#10 Frisco
Frisco
  • 414 posts
Posted 06 December 2011 - 09:25 PM
Easiest way to explain plastigauge.
Ignore the geek doing it and the fact that its a v8 in the vid the procedure is the same. Its cheap,really easy and gives a very good reading of the clearance.
A machine shop will no doubt do it for you quicker but I suppose I like doing things myself
#11 andymini12
andymini12
  • 812 posts
Posted 06 December 2011 - 09:47 PM
Thanks for that,
can you also messure the journal with a micrometer?
#12 R1minimagic
R1minimagic
  • 4,660 posts
Posted 06 December 2011 - 09:49 PM
Yes if you have one
#13 andymini12
andymini12
  • 812 posts
Posted 06 December 2011 - 10:27 PM
Yes i will do, waiting for it to come,
What should the messurment be?
is this right?
main bearing 2.0005-2.0010in
big end's 1.7504-1.7509in
#14 bmcecosse
bmcecosse
  • 9,699 posts
Posted 06 December 2011 - 11:10 PM
It looks fine to me - if the journals were worn there would also be some scoring> Check with micrometer by all means but I would just reshell it.
#15 Ethel
  • 25,920 posts
Posted 07 December 2011 - 02:49 AM
I'd kind f go with bmcecosse, if it looks good it probably is. If you're really interested in doing a tip top job then it'd be best taking it to a machine shop. The journals can measure up with the thickness within tolerance but it won't tell you if they a perfectly round or parallel/congruent to the other journals. The only way to check that is to centre & turn the crank, with a dial gauge running on the journals.
