Changing Front Bump Stops
32 replies to this topic
#1 racingbob
racingbob
  • 3,061 posts
Posted 06 December 2011 - 11:37 AM
how do you get in there to take off bump stops on front single bolt type
havent done it before cant get spanner in
want to put some new ones on maybe the poly ones from mini spares
#2 JustSteve
JustSteve
    Puke-Boy!!
  • 1,883 posts
Posted 06 December 2011 - 11:51 AM
you have to remove he cones first... pain in the arse, I know! Even then it can be tight!
Good luck :thumbsup:
#3 jaydee
jaydee
  • 8,565 posts
Posted 06 December 2011 - 11:54 AM
Try one of those little sockets, but problem is finding a way to reach them with your hands. But most times they're not very tight and you can undo them easily whiggling the bump stop, refitting will be awkward though.
I usually do them when replacing cones, so i remove top arm at the same to give it a clean and check, then replace bump stops and knuckle joints too..
#4 racingbob
racingbob
  • 3,061 posts
Posted 06 December 2011 - 12:21 PM
thanks for the advice
#5 zef
zef
  • 223 posts
Posted 06 December 2011 - 08:42 PM
To remove them use a slicing disc in an angle grinder and to fit new one's get them as tight as possible (this works on standard one's, not sure about poly one's) and then tack a spot of weld on the metal part to the subframe.
#6 1984mini25
1984mini25
  • 8,784 posts
Posted 06 December 2011 - 09:05 PM
What I've always done is use a tiny 7/16th spanner to hold the nut and screw/unscrew the bump stop. Or if it won't shift or the rubber part comes away, it's out with the grinder.
Edited by 1984mini25, 06 December 2011 - 09:05 PM.
#7 bmcecosse
bmcecosse
  • 9,699 posts
Posted 06 December 2011 - 11:19 PM
You can put a bend into a small spanner to get at them. Not the cleverest design. The hydro bump stops and the competition Aeon stops fit over the top arm - worth considering!
#8 maccers
maccers
  • 1,867 posts
  • Local Club: LSMOC
Posted 01 February 2014 - 02:14 PM
Before I done this earlier I checked here, so thought I'd update it for future searches. I wanted to remove the thick washer so loosened it up a bit with some grips, just turning it a bit, the nut was quite tight on so I needed to get a spanner on it. I used a small 11mm and managed to get it on the nut. The suspension is fully assembled, space is a bit tight but works fine. Undone the bump stop by turning it with my free hand, removed washer and then threaded it back into nut still being held with spanner in other hand..! Other side was the same, took about 2 mins...! I don't have the smallest hands in the world either.
#9 AlasdairM
AlasdairM
  • 240 posts
Posted 01 September 2020 - 06:16 PM
Thanks for the update, I’m going to attempt this myself without disassembling the suspension...
#10 sonscar
sonscar
  • 2,995 posts
Posted 01 September 2020 - 07:01 PM
Absolutely no need to dismantle the suspension,creativity may be required but it is probably a Haynes half spanner task.The problem is what else might you see?Have fun,Steve..
#11 AlasdairM
AlasdairM
  • 240 posts
Posted 01 September 2020 - 07:06 PM
So a stubby 11mm spanner should do the job?
#12 1314cc
1314cc
  • 302 posts
  • Local Club: tumbleweedminisbristol
Posted 01 September 2020 - 08:26 PM
I used an old thin spanner which I bent to fit. It's a right pain but can be done. Fingers will be cut that's guaranteed!!!
#13 GraemeC
GraemeC
  • 7,438 posts
Posted 02 September 2020 - 07:30 AM
No - 7/16" AF
#14 gazza82
gazza82
  • 3,012 posts
  • Local Club: TMF+
Posted 02 September 2020 - 09:48 AM
You won't find many metric fittings on a Classic Mini .. invest in a set of AF spanners/sockets!
#15 AlasdairM
AlasdairM
  • 240 posts
Posted 02 September 2020 - 10:04 AM
Thanks, I mentioned an 11 as someone above said that would fit. I've already got standard spanners and sockets in metric and imperial- but no stubby spanners yet. Since metric stubby spanners may come in more useful, I'd rather buy them, than have to buy two stubby sets!
