Hadrian Body Panels In Administration?
Posted 05 December 2011 - 10:02 AM
Anyone know anymore about this?
Posted 05 December 2011 - 11:20 AM
Posted 05 December 2011 - 12:24 PM
Posted 05 December 2011 - 12:28 PM
Posted 05 December 2011 - 05:36 PM
Hadrian are not magnum. two different companies all together.
Posted 05 December 2011 - 11:40 PM
Posted 08 December 2011 - 09:08 PM
Posted 08 December 2011 - 10:32 PM
Posted 08 December 2011 - 10:39 PM
Posted 08 December 2011 - 10:40 PM
- they arent allways a good fit and most still require tweeking, as do pattern panels
- they cost more
- they are less available usually (ie. pattern panels available from more local stockists)
- a pattern panel will last as long if fitted and preped/painted/protected properly.
Secondly, theres still others producing panels
Posted 08 December 2011 - 11:09 PM
why should you use hertiage panels?
- they cost more
Plus not all genuine panels are available, you try finding a gen inner sill or flinch/hinge panels for example.
Posted 09 December 2011 - 10:56 AM
They always fit much better than pattern, yes they require a small amount of tweeking not major stuff like hadrian and magnum pattern panels I have used in the past, half the time they are too short too long or just plain wrong, for example the door hinge panel they make the stamping on them is the wrong way round! the inner sill on the floor pan is too short the boot repair panel the long one was too short and the curve/radius where it meets the boot hinge panel is completely wrong, Took me ages to fit that panel.
- they cost more
They cost more but they have a decent finish on them you don't need to remove first, they are made of the correct guage steel, they actually fit properly and to be honest just the amount of time you save fitting genuine as opposed to pattern more than make up for the cost. and you are supporting a company trying to keep the genuine parts in production and who care about quality.
agreed they are abit harder to get hold of locally, which is a shame.
yes agreed as long as you remove that horrible finish they come with. to put it into perspective I have one genuine wing and one non genuine wing on my mini fitted at the same time, the genuine one is fine however the pattern one has rusted through and is now being replaced with a genuine one. I believe as the original finish wasn't removed prior to painting.
Posted 09 December 2011 - 09:26 PM
Posted 13 December 2011 - 07:44 PM
