Installing Gearbox To Engine & Transfer Case Gaskets
6 replies to this topic
#1 mk=john
mk=john
  • 1,167 posts
  • Local Club: Milton Keynes Mini Club, Mini Cooper Register
Posted 03 December 2011 - 10:06 AM
Hi
I am just double checking about this.
I am about to install the gearbox onto my engine (850cc). Is the recommended method to run grease along the gaskets which go between the engine/gearbox, and engine/transfer case?
I guess if that if RTV was used I would never be able to get them apart in the future.
I think that RTV on the half moon seal at the camshaft end cant hurt?
#2 Jordie
Jordie
  • 13,567 posts
  • Name: Jordan
Posted 03 December 2011 - 10:23 AM
i normally use grease to stop them moving yeah.
#3 Guess-Works.com
Guess-Works.com
    Gearbox Guru
  • 19,838 posts
Posted 03 December 2011 - 10:25 AM
correct, don't use RTV on any gasket, run a beed of RTV around the front main cap and then sit the 1/2 moon seal on it, run a similar bead of RTV around the mating face on the gearbox.
Using grease on the gasket does not clog the gasket up, it is a porous material which will use the grease and oil from the transmission to provide a fluid tight seal, like corking if you're a boat builder...
#4 Ethel
  • 25,920 posts
Posted 03 December 2011 - 10:26 AM
http://www.minispare...x?ty=ad&aid=107
silicone on the C seal will be fine, just be careful any excess can't block any oilways
#5 mk=john
mk=john
  • 1,167 posts
Posted 03 December 2011 - 10:40 AM
Great
Also, is using Hylomar Blue gasket sealant on the half moon rubber seal OK? Or must it be RTV?
Edited by mk=john, 03 December 2011 - 10:40 AM.
#6 Ethel
  • 25,920 posts
Posted 03 December 2011 - 11:20 AM
RTV will be better, it sets.
#7 firefox
firefox
  • 1,102 posts
  • Local Club: will find one when on the road
Posted 03 December 2011 - 11:58 AM
I used a Hylomar sandwich on the gasket and rtv around the seal, hylomar does not set and will allow you to dismantle
