Subframe Identity Question
2 replies to this topic
#1 aavayro
aavayro
  • 89 posts
  • Local Club: D.C.M.O.C
Posted 02 December 2011 - 07:25 PM
Hello i have acquired a front subframe believed to be a metro frame , although the engine i have does not fit the fit the frame.
The engine i have is out of a pre 1994 metro gta, 1400 8v. The location of the engine mountings on the frame are nothing like the ones on the engine.
The frame i have has still retains metro hydo suspension and has a engine mounting on the front and back, no mountings located on the timing belt side and two on the gearbox side, it also has a anti roll bar fitted to the front,
Was wondering if anyone could tell me what model this frame is put of and whether i could still use this?? was wondering if the frame the frame is from a Rover 100 or 214??
Any help would be great..
#2 gadget555
gadget555
  • 152 posts
Posted 03 December 2011 - 10:46 AM
some pictures would help !
#3 kcchan
kcchan
  • 874 posts
Posted 03 December 2011 - 11:52 AM
It should just be a case of swapping engine mounts over. Get a few pictures up of the subframe and someone should be able to tell you what it was originally from and which car you want the engine mounts from.
