1380Cc... 1 3/4" Or 2" Exhaust System?
9 replies to this topic
#1 colinu
colinu
  • 517 posts
  • Local Club: MOASF
Posted 02 December 2011 - 08:13 AM
Will be fitting my recently built 1380cc engine soon. I currently have a large bore Maniflow system (2" LCB, pipe, and rear box). Is that best for a 1380cc or should I use a 1 3/4" system instead?
Note this isn't a wild/race build - more of a fast road with manners using a big valve stage4 head and ACD-RS+ cam (no aim to rev this over 6500rpm).
#2 Gulfclubby
Gulfclubby
    Gulf Boy
  • 751 posts
  • Name: Ben
  • Local Club: Berner Mini Club
Posted 02 December 2011 - 08:37 AM
I'd say if you don't want to rev it too high and have a correspondingly mild cam to go with the engine, the smaller exhaust diameter will give you a little more oomph.
#3 bmcecosse
bmcecosse
  • 9,699 posts
Posted 02 December 2011 - 10:28 AM
Big engine = big exhaust. It will be fine.
#4 Guess-Works.com
Guess-Works.com
    Gearbox Guru
  • 19,838 posts
Posted 02 December 2011 - 10:44 AM
or in the middle, 1.7/8"
#5 Cooperman
  • 23,276 posts
Posted 02 December 2011 - 03:36 PM
If you have a 2" system already I would say use it.
By choice a 1.75" might be slightly better, but as it's 1380 I doubt you would actually notice any difference.
#6 E.L.M.O
E.L.M.O
  • 3,953 posts
Posted 02 December 2011 - 04:09 PM
Personally for my 1380 I am going 1 3/4" and a 2" pipe.
#7 colinu
colinu
  • 517 posts
  • Local Club: MOASF
Posted 02 December 2011 - 04:14 PM
OK, I'll stick with my Maniflow 2"... and save myself a small fortune (full systems ain't cheap here in the USA).
Or here's another thought...
What if I keep the 2" LCB and back box, and connect them with a 1 3/4" pipe? Maybe a good/cheaper compromise???
#8 Gulfclubby
Gulfclubby
    Gulf Boy
  • 751 posts
  • Name: Ben
Posted 02 December 2011 - 04:17 PM
In any case, the difference is going to be marginal at best. I wouldn't spend too much time worrying about this and simply fit the existing setup.
#9 E.L.M.O
E.L.M.O
  • 3,953 posts
Posted 02 December 2011 - 04:57 PM
Yeah I agree with that to be honest, its only something worth deciding if you have neither and need to buy a setup. Go with what you got!
#10 racingbob
racingbob
  • 3,061 posts
Posted 02 December 2011 - 10:10 PM
my system on my 1380 was 2" but was race engine 110bhp at wheels
2" should be fine tho i had other engine 1330 rev to 7000 max and was fine with the same exhaust
