Weights
123 replies to this topic
#106 miniweights
miniweights
  • 199 posts
Posted 22 September 2013 - 06:47 PM
Some more weights added :-)
Please be aware, identical parts can often have slightly different weights.
Weights
Kerb Weights:
Mk 1 Saloon (Rubber Cone Suspension): 587 kg
Mk1 Saloon (Hydrolastic Suspension): 634.5 kg
Van: 605 kg approx
Traveller & Countryman: 660 kg
Pickup: 604 kg
Moke: 562 kg
Mk 3 Saloon Mini 1000cc (Manual Transmission): 638 kg
Mk 3 Saloon Mini 1000cc (Automatic Transmission): 658 kg
Mini Clubman Saloon 998cc: 638 kg
Mini 1275 GT: 655 kg
1991-2000 Mini Cooper 1.3i: 690 kg
BODY
Bodyshell (Bare): 140.6 kg
Bonnet Hook Safety Catch: 0.051 kg
Bonnet Hinge (Mk3 including bolt, nuts x 3 & washers x 6) 0.132 kg
Bonnet Locking Pin & Spring: 0.075 kg
Bonnet Mk2: 7.7 kg
Bonnet Mk3 (Stripped): 5.900 kg
Bonnet Prop & Fixings Mk3: 0.145 kg
Bonnet Release Lever Mechanism Assembly: 0.293 kg
Boot Badge (Mini 1000) Mk3: 0.052 kg
Boot Handle & Catch Assembly Mk3: 0.272 kg
Boot Hinge & Fixings each: 0.185 kg
Boot Lid Cables & Fixings each side: 0.022 kg
Boot Lid Mk3 (Stripped): 4.305 kg
Boot Lid Mk3 (Complete with all parts including hinges): 5.582 kg
Boot Number Plate Light Unit & Fixings Mk3: 0.495 kg
Boot Rubber Seal (Fitted to boot) Mk3: 0.254 kg
Boot Rubber Seal Clips x 26 Mk3: 0.019 kg
Boot Rubber Seal (Fitted to body): 0.410 kg
Bumpers (BMC Cooper S) each: 2.150 kg
Bumpers (Chrome) each: 1.650 kg
Bumper Front (1275 GT): 2.450 kg
Bumper Rear (1275 GT): 1.990 kg
Bumper Over Rider each: 0.260 kg
Companion Bin Cards pair: 0.390 kg
"C" Pillar Cards pair: 0.209 kg
Dash Ashtray Mk3: 0.063 kg
Dash Bottom Rail Cover Mk3: 0.413 kg
Dash Card: 0.540 kg
Dash Centre Binnacle (Including Speedo, Water & Oil Gauges): 1.262 kg
Door Catch/Lock Assembly Mk3 (On Door): 0.321 kg
Door Catch/Jam & Striker Plate Mk3 (On Body Pillar): ? kg
Door Handle Mk3 (including lever): 0.355
Door Hinge Support Plate Stainless (each):
Door Hinge Nuts & Washers Stainless (per hinge):
Door Hinge Lower Mk3: 0.283 kg
Door Hinge Upper Mk3: 0.296 kg
Door Lock Lever Assembly Mk3: 0.064 kg
Door Mk 1 & 2 Complete (Not including hinges): 15.0 kg
Door Mk3 with side impact bar. Complete with hinges (Not including mirror): 18,6 kg
Door Card Mk3 on (each): 1.128 kg
1/4 Panel Card each: 0.784 kg
Door Catch Assembly (Body Pillar) each side: 0.193 kg
Door Check Mk3 each: 0.067 kg
Door Check Seal Mk3 each: 0.031 kg
Door Exterior Handle & Fixings Mk3 each: 0.363 kg
Door Glass & Channel Mk3 each side: 4.365 kg
Door Glass Front Section Mk1 & 2 (per door): 1.913 kg
Door Glass Front Section Catch Mk1 & 2 (per door): 0.030 kg
Door Glass Rear Section Mk1 & 2 (per door): 1.402 kg
Door Glass Rear Section Catch Mk1 & 2 (per door): 0.027 kg
Door Interior Handle & Fixings Mk3 each: 0.042 kg
Door Locking Lever Mechanism Mk3 each: 0.066 kg
Door Opening Lever & Fixings Mk3 each: 0.038 kg
Door Release Rod Mechanism each: 0.203 kg
Door Surround Rubber Seal (each): 0.880 kg
Door Skin Steel (Mk3): 4.079 kg
Door Window Winder Guide each: 0.216 kg
Door Window Winder Guide Rubber each: 0.039 kg
Door Window Winder Handle Mk3 each: 0.035 kg
Firewall Hole Cover Rear Mk3: 0.163 kg
Flitch Panel Air Vent Blanking Cover each: 0.052 kg
Front End Carbon Fibre One Piece (Carbon Weezel Product) 1.6 – 2.2 kg Depending on spec
Front End Carbon Fibre Two Piece (Carbon Weezel Product) 2.0 – 2.8 kg Depending on spec
Front End Steel Non Genuine Panels (not including bonnet): 9.0 kg Approx
Front Grille Bonnet Trim Mk2 & 3: 0.115 kg
Front Grille Side Trim Mk2 & 3 (each side): 0.051 kg
Front Grille 8 Slat Mk3: 1.176 kg
Front Panel: 4.185 kg
Front Seat (BMC Cooper S) each: 7.270 kg
Front Seat (1275 GT) each: 7.260 kg
Front Wing (early): 2.340 kg
Headlamp Bowl Kit Metal Complete (per side): 0.568 kg
Headlamp Bowl Kit Plastic Complete (per side): 0.250 kg
Headlamp Sealed Beam Unit (each): 0.540 kg
Interior Mirror Mk3 & Fixings: 0.113 kg
Number Plate (Plastic) each: 0.231 kg
Number Plate (Pressed Alloy) each: 0.187 kg
Parcel Shelf Card: 0.721 kg
Rear Wheel Arch Trim pair: 0.056 kg
Rear Companion Bin (each): 0.900 kg approx
Rear Companion Bin Trim (each): 0.100 kg approx
Rear Light Unit Mk2/3 & Rubber Gasket each side: 0.651 kg
Rear Quarter Window (Opening) Mk1 & 2 each: 3.218 kg
Rear Quarter Window (Opening) Mk3 each: 3.373 kg
Rear Seat Squab (Mk3 Cloth with Vinyl edges): 2.298 kg
Rear Seat Cushion (Mk3 Cloth with Vinyl edges): 2.225 kg
Seam Finisher Front (each): 0.110 kg
Seam Finisher Rear (each): 0.128 kg
Seam Finisher Clips (x 30): 0.022 kg
Subframe Front Dry (early twin bolt): 16.7 kg
Subframe Tower Spacer Plate (each): 0.138 kg
Subframe Top Mount Tab Plates Twin Bolt Including Rubber Grommet (each): 0.030 kg
Subframe Top Mount Bolt Twin Bolt (each): 0.062 kg
Subframe (Rear): 14.2 kg
Subframe (Rear) Front Mounting Pin & Nut (per side): 0.197 kg
Subframe (Rear) Trunnion early (each): 0.181 kg
Window (Rear Mk2 on): 4.090 kg
Window Rear Rubber Seal (Mk3 on): 1.054 kg
Windscreen Front (Laminated): 5.700 kg
Windscreen Front Rubber Seal (without insert): 1.152 kg
Windscreen Front Rubber Seal Insert: 0.217 kg
Window Winder Mechanism each: 1.510 kg
ENGINE
Alternator: 4.335 kg
Alternator Adjustment Bracket (curved): 0.051 kg
Alternator Adjustment Bracket (straight): 0.062 kg
Alternator Adjustment Bracket Bolt, Nut & Washers: 0.033 kg
Alternator to Adjustment Bracket Bolt & Washer: 0.014 kg
Alternator Mounting Bracket to Block A: 0.186 kg
Alternator Mounting Bracket to Block A+: 0.075 kg
Alternator Mounting Bracket Bolts Flanged x 2: 0.024 kg
Alternator Mounting Bracket Bolts & Washers x 2: 0.028 kg
Alternator Mounting Bolts, Nuts & Washers x 2: 0.054 kg
Big End Connecting Rod Bearing Set: 0.182 kg
Camshaft SW05-07: 1.850 kg
Camshaft Woodruff Key: 0.002 kg
Camshaft Followers x 8: 0.369 kg
Camshaft Thrust Plate: 0.033 kg
Cam Thrust Plate 1/4" UNF Bolts & Star Washers x 3: 0.021 kg
Camshaft Duplex Vernier Sprocket: 0.725 kg
Camshaft Key Washer: 0.043 kg
Camshaft Lock Tab Washer: 0.014 kg
Camshaft Retaining Nut: 0.027 kg
Carburettor HIF-38: 1.388 kg
Coil Engine Bracket (L shape): 0.108 kg
Coil Engine Bracket (L shape) Bolts & Washers x 2: 0.028 kg
Coil Retaining Bracket: 0.074 kg
Cooling Fan Plastic 11 Blade: 0.165 kg
Connecting Rods x 4: 2.600 kg approx
Connecting Rod (BMC 1275 Cooper S) each: 0.680 kg
Core Plugs x 5: 0.080 kg
Countersink Screws on Timing Plate for Duplex Gears: 0.008 kg
Crankshaft (BMC 1275 Cooper S): 11.430 kg
Crankshaft Duplex Sprocket: 0.323 kg
Crankshaft Oil Thrower: 0.026 kg
Crankshaft Main Bearings Set: 0.170 kg
Crankshaft Pulley Bolt: 0.144 kg
Crankshaft Pulley Locking Tab Washer: 0.014 kg
Crankshaft Pulley TAM2011: 1.290 kg
Crankshaft Sprocket Packing Washer: 0.000.5 kg
Crankshaft Thrust Washer Set: 0.076 kg
Crankshaft Woodruff Key: 0.004 kg
Cylinder Head 12G940B Valves Fitted: 13.852 kg approx
Cylinder Head 12G940 MG Valves Fitted: 12.50 kg approx
Cylinder Head Gasket: 0.092 kg
Cylinder Head Studs & Nuts Short x 5: 0.320 kg
Cylinder Head Studs & Nuts Long x 4: 0.344 kg
Distributor 65DM4 Electronic: 0.796 kg
Distributor Clamp: 0.081 kg
Distributor Clamp Bolt & Washer: 0.026 kg
Distributor Drive Spindle A+: 0.194 kg
Dipstick A+ Stainless Steel: 0.90 kg
Dynamo Rear Mounting Bracket: 0.101 kg
Duplex Timing Chain: 0.381 kg Typo Corrected
Engine Earth Strap: 0.059 kg
Engine Mount (each): 0.250 kg
Engine Mount to Clutch Cover Bolts & Washers: 0.039 kg
Engine Mount to Radiator Bracket Bolts & Washers: 0.036 kg
Engine Mount to Subframe Nuts, Bolts & Washers (per mount): 0.036 kg
Engine Steady Bar Adjustable (Including Poly Bushes): 0.311 kg
Engine Steady Bracket (on engine): 0.062 kg
Engine Steady Bracket Bolts & Washers x 2 (on engine): 0.035 kg
Engine to Gearbox Bolts, Washers, Studs & Nuts: 0.130 kg
Exhaust Centre Pipe Section RC40 (Twin Box): 1.237 kg
Exhaust Fitting Kit RC40: 0.820 kg
Exhaust Manifold LCB (Fletcher): 2.705 kg
Exhaust Manifold LCB “Y” Piece Including Brackets (Fletcher): 0.940 kg
Exhaust Twin Box Section RC40 (Side Entry): 5.557 kg
Exhaust Valve 29,2mm each: 0.046 kg
Fuel, Water, Oil Pump & Oil Filter Housing Gaskets: 0.004 kg
Fuel Pump Blanking Plate: 0.055 kg
Fuel Pump Blanking Plate Bolts & Washers x 2: 0.026 kg
HT Leads set of 5 x 8mm Silicone: 0.250 kg
Inlet Manifold CAM6618 (Worked): 0.744 kg
Inlet Valve 33.33mm each: 0.050 kg
Manifold Gasket: 0.041 kg
Oil Filler Cap (Black): 0.034 kg
Oil Filler Cap (Red): 0.043 kg
Oil Filter (Paper): 0.084 kg
Oil Filter Housing & Oil Feed Pipe: 0.315 kg
Oil Filter Housing Studs, Nuts & Washers x 2: 0.060 kg approx
Oil Feed Pipe Banjo Bolt & Washers: 0.064 kg
Oil Filter Spin On: 0.309 kg
Oil Pressure Light Switch: 0.025 kg
Oil Pressure Relief Assembly: 0.070 kg
Oil Pressure T Piece with Adaptor Fitting: 0.071
Oil Pump: 0.493 kg
Oil Pump Bolts Flanged x 2: 0.025 kg
Piston with Rings & Pin (BMC 1275 Cooper S) each: 0.354 kg
Primary Gear with Bush: 0.570 kg
Primary Gear "C" Washer Assembly: 0.038 kg
Primary Gear Thrust Washer: 0.018 kg
Push Rods x 8 (1275): 0.421 kg
Radiator Bottom Mount: 0.167 kg
Radiator Top Mount: 0.123 kg
Rocker Cover Alloy CAM6822: 0.748 kg
Rocker Cover Brackets for splash guard: 0.061 kg
Rocker Cover Rubber Seals (pair): 0.008 kg
Rocker Cover Steel: 0.586 kg
Rocker Cover T Bars (pair): 0.091 kg
Rocker Cover Gasket: 0.025 kg
Rocker Post Stud & Nut Short x 2: 0.059 kg
Rocker Post Stud & Nut Long x 2: 0.067 kg
Rocker Shaft Assembly: 1.489 kg
Rocker Stud Tab: 0.004 kg
Rotor Arm for 65DM4: 0.016 kg
Short Engine 1275 A+ Including the following parts fitted: Pistons – Con Rods – Crankshaft – Camshaft – Cam Followers – Oil Pump – Oil Pressure Relief Valve Assembly: 53.4 kg
Standard Flywheel 7.58 kg
Spark Plugs x 4: 0.224 kg
Starter Motor Inertia 4.4 kg
Starter Motor Pre-engaged 4.5 kg
Thermostat: 0.075 kg
Timing Chain Back Plate (Alloy): 0.388 kg
Timing Chain Cover A+ with Breather: 0.621 kg
Timing Cover 1/4" Bolts, Plain & Locking Washers x 6: 0.042 kg
Timing Cover Crankshaft Oil Seal: 0.023 kg
Timing Plate: 1.000 kg
Timing Plate 5/16" Bolts & Washers x 6: 0.076 kg
Timing Plate & Cover Gaskets: 0.014 kg
Valve Spring (Single) each: 0.040 kg
Valve Spring Cap each: 0.015 kg
Valve Stem Collets x 8 Pairs: 0.016 kg
Valve Stem Seals x 4: 0.006 kg
Water Pump Bolts Flanged x 4: 0.079 kg
Water Pump Bolts & Washers x 4: 0.078 kg
Water Pump Pulley 3.7/8": 0.231 kg
Water Pump Pulley 4.11/16": 0.290 kg
Water Pump (with bypass): 0.865 kg
Water Pump (without bypass): 0.785 kg
Water Temperature Sender Switch: 0.030 kg
TRANSMISSION
Clutch Case Cover with Verto Lever: 2.100 kg
Clutch Case Cover with Pre Verto Lever: 2.233 kg
Clutch Cover Diaphragm Pre Verto: 0.818 kg
Clutch Friction Plate Pre Verto: 0.579 kg
Clutch Friction Plate Verto: 0.825 kg
Clutch Lever Return Spring: 0.010 kg
Clutch Master Cylinder: 0.680 kg
Clutch Master Cylinder Clevis Pin & Split Pin: 0.008 kg
Clutch Pressure Back Plate Standard Lightened (Pre Verto): 1.978 kg
Clutch Pressure Back Plate Standard (Pre Verto): 2.600 kg*
Clutch Pressure Plate Assembly (Verto): 4.2 kg
Clutch Release Bearing: 0.085 kg
Clutch Release Bearing Clip: 0.002 kg
Clutch Slave Cylinder (Pre-Verto): 0.540 kg
Clutch Shouldered Bolts Competition Long x 3: 0.064 kg
Clutch Shouldered Bolts Competition Short x 3 0.053 kg
Clutch Spring Anchor Tab: 0.005 kg
CV Joint Outer (each): 1.700 kg
Drive Flange Alloy each: 0.57 kg
Drive Flange each: 1.47 kg
Drive Shaft Nearside Short: 1.286 kg
Drive Shaft Offside Long: 1.575 kg
Flywheel (BMC 1275 Cooper S): 7.360 kg
Flywheel complete with Clutch (BMC 1275 Cooper S): 11.890 kg
Flywheel Housing (A+): 3.231 kg
Flywheel Housing Gasket: 0.022 kg
Flywheel Key Washer to Crankshaft:
Flywheel Housing Lock Tab (2 hole): 0.005 kg
Flywheel Housing Lock Tab (3 hole long): 0.008 kg
Flywheel Housing Lock Tab (3 hole short): 0.007 kg
Flywheel Housing Oil Seal: 0.028 kg
Flywheel Standard Pre Verto: 7.580 kg
Flywheel Lightened Standard Pre Verto: 6.050 kg
Flywheel Bolt: 0.105 kg
Gearbox (Including all gears & differential): 26 kg approx
Gearbox to Engine Gaskets: 0.004 kg
Gear Lever Rod Change without Gearknob: 0.651 kg
Gear Lever Kad Quickshift without Gearknob: 0.732 kg
Gear Lever Rubber Gaiter (remote change): 0.173 kg
Hub Front (with bearings fitted): 1.337 kg
Hub to Brake Disc Bolts x 4 (per side): 0.064 kg
Hub Wheel Stud Standard (each): 0.019 kg
Primary Gear (998 A+): 0.616 kg
Remote Gearchange Rear Support Bracket (Including Nuts, Bolts & Washers: 0.306 kg
Rod Gearchange Linkage (Including Support Bracket): 2.095 kg
Rod Gearchange Linkage Roll Pin: 0.003 kg
Sump Plug Washer: 0.004 kg
SUSPENSION
Bumpstop early two stud including Nuts & Washers (per side): 0.089 kg
Front Suspension Alloy Cone Strut Including Knuckle Joint (each): 0.295 kg
Front Suspension Bottom Arm (each): 0.840 kg
Front Suspension Bottom Arm Bushes (per side): 0.037 kg
Front Suspension Bottom Arm Pin including Nut & Washer (per side): 0.219 kg
Front Upper Arm Complete Assembly Knuckle Joint, Nuts, Bolts & Washers (each): 2.392 kg
Genuine Rubber Suspension Cone (each): 0.904 kg
Knuckle Joint (each): 0.136 kg
Radius Arm including Pin, Bush & Bearing (each): 5.089 kg
Radius Arm Fully Built Including Non Spacered Drum (each): 11.120 kg
Radius Arm Fully Built Including Spacered Drum (each): 12.500 kg
Rear Hub Alloy (Mini Sport) each: 0.419 kg
Rear Hub Nut (per side): 0.028 kg
Rear Hub Standard (not including bearings) each: 0.931 kg
Rear Hub Standard Including Bearings, Nut, Split Pin, & Cap: 1.445 kg
Rear Subframe Poly Bushes x 4 (per side): 0.042 kg
Rear Suspension Alloy Cone Strut Including Knuckle Joint (each): 0.670 kg
Rebound Buffer (per side): 0.023 kg
Shock Absorbers Front Gaz Adjustable (each): 1.416 kg
Shock Absorbers Front Standard (each): 0.818 kg
Shock Absorbers Rear Gaz Adjustable (each): 1.520 kg
Shock Absorbers Rear Standard (each): 0.650 kg
Shock Absorber to Radius Arm Nut & Washers (per side): 0.017 kg
Shock Absorber Top Mount (per side): 0.409 kg
Tie Bar Rod Heavy Duty Adjustable (each): 0.845 kg
Tie Bar Rod Standard (each): 0.498 kg
Tie Bar Rod to Bottom Arm Nut & Bolt (per side): 0.024 kg
Tie Bar Rod Front Nut & Washer (per side): 0.045 kg
STEERING
Steering Rack Retaining "U" Bolts & Nuts (pair): 0.139 kg
Steering Rack to Body Seal: 0.001 kg
Steering Column complete with Steering Wheel Nut & Steering Lock: 2.573 kg
Steering Column Pinch Bolt, Nut & Spring Washer: 0.015 kg
Steering Column Bracket (Painted): 0.090 kg
Steering Column Bracket (Chrome): 0.096 kg
Steering Column Bracket Shear Bolts & Washers (pair): 0.037 kg
Steering Column Bracket Shear Bolt Threaded Back Plate: 0.040 kg
Steering Column to Bracket Nut, Bolt & Washer: 0.034 kg
Steering Column Cowling (Mk3): 0.172 kg
Steering Rack: 3.608 kg
Steering Rack Track Rod End Locking Nut (each): 0.012 kg
Steering Wheel Retaining Nut (early): 0.044 kg
Track Rod End Long (each): 0.312 kg
Track Rod End Standard (each):
Swivel Hub Alloy (Mini Sport) each: 0.71 kg
Swivel Hub Standard with Bearings, Steering Arm & Joints (per side): 3.055kg
Swivel Hub Standard each: 1.73 kg
BRAKES
Brake Caliper Pad Split Pins x 2 (per side): 0.012 kg
Brake Drum Rear Alloy Finned Built In Spacer (each): 1.750 kg
Brake Drum Rear Non Spacered (each): 2.288 kg
Brake Drum Rear Built In Spacer (each): 3.620 kg
Brake Drum Retaining Screws Long x 2 (per side): 0.016 kg
Brake Drum Retaining Screws Short x 2 (per side): 0.006 kg
Brake Light Pressure Switch & 2 Way Union Assembly: 0.132 kg
Brake Pads 8.4" (per side): 0.302 kg
Brake Pad Clip 8.4" (per side): 0.006 kg
Brake Rear Adjuster & Tappets: (per side): 0.073
Brake Regulator Valve (Early): 0.356 kg
Brake Shoes Rear (both sides): 0.891 kg
Brake Shoe Rear Return Springs (per side): 0.048 kg
Brake Union 3 Way: 0.054 kg
Caliper Alloy Four Pot: 1.15 kg
Caliper Metro Four Pot: 3.48 kg
Caliper Two Pot 7.5": 2.66 kg
Caliper Two Pot 8.4": 3.479 kg
Caliper 8.4" Mounting Bolts & Washers (per side): 0.053 kg
Disc 8.4": 2.906 kg
Disc 8.4” Back Plate (each): 0.365 kg
Discs Vented 7.9 pair: 6.5 kg
Discs Vented 8.4 pair: 6.9 kg
Discs Rear KAD pair: 2.8 kg
Handbrake Cable Back Plate Bracket (per side): 0.074 kg
Handbrake Cable Drum Lever: 0.107 kg
Handbrake Fairlead Pad (each): 0.009 kg
Handbrake Fairlead Plate (each): 0.009 kg
Handbrake Lever (early two cable) including mounting nuts, bolts & washers: 0.780 kg
Handbrake Lever (later single cable) including mounting nuts, bolts & washers: 0.510 kg
Handbrake Lever Grip (late): 0.071 kg
Handbrake Quadrant Alloy (per side): 0.030 kg
Handbrake Quadrant (per side): 0.112 kg
Handbrake Quadrant Bolt, Nut & Washer (per side): 0.050 kg
Hub & Disc 8.4" Assembly: 4.389 kg
Master Cylinder Single (early): 0.610 kg
Rear Brake Back Plate: 0.826 kg
Rear Brake Back Plate Bolt, Nut & Washer x 3 (per side): 0.066 kg
Rear Brake Cylinder: 0.351 kg
Rear Brake Cylinder "C" Clip & Gasket (per cylinder): 0.003 kg
Rear Brake Shoes Pair (per side): 0.464 kg
MISCELANEOUS
Fluids
Coolant Capacity: 3.5 litres = 3.5 kg
Water: 1 Pint approx 0.575 kg
Unleaded Petrol 1 Gallon (4.54 Litres) at 69 deg F (20 deg C): 3.324 kg
Fuel System
Fuel Tank 5.5 Gallon (25.0034 Litres): 4.437 kg
Fuel Tank Retaining Strap 5.5 Gallon: 0.318 kg
Locking Petrol Cap: 0.137 kg
Engine Bay
Bonnet Buffers Clubman pair: 0.015 kg
Bonnet Buffers Round Nose eary pair: 0.006 kg
Horn Mk3 Factory Fitted: 0.775 kg
Master Cylinder Mounting Plate: 0.110 kg
Voltage Regulator Control Box: 0.427 kg
Windscreen Washer Bottle Including Electric Pump: 0.275 kg
Windscreen Washer Pipe Assembly Including "T" Piece (bulkhead mounted): 0.026 kg
Wiper Hole Blanks Stainless (pair): 0.041
Wiper Mechanism (Mk3): 0.579 kg
Wiper Motor 2 Speed (Mk3): 1.628 kg
Wiper Motor to Body Rubber Pad: 0.026 kg
Wiper Mounting Bracket Including Rubber: 0.098 kg
Interior
Accelerator Pedal (without rubber): 0.272 kg
Centre Speedo Cowl Surround (3 gauge type stripped): 0.266 kg
Dash Ashtray: 0.061 kg
Door Release Rod Mechanism (each): 0.203 kg
Interior Mirror including fixing Screws (late black plastic): 0.143 kg
Pedal Box: 2.100 kg
Roll Cage Safety Devices Six Point Bolt In (Including Fixings):
Roll Cage Rear Section with Diagonal: 15 kg
Roll Cage Front Section: 10 kg
Roll Cage Dash Bar: 3 kg
Roll Cage Door Bar (Each): 2.5 kg
Seat Cobra Classic (not including Subframe) 6.1 kg
Seat Mamba Classic (not including Subframe) 6.7 kg
Seat Cross Member Front Mount (Mk3 bolt-on) Each: 0.144 kg
Seat Catch Floor Brackets (each): 0.272 kg
Sound Deadening (floor & rear quarter panels): 9.0 kg approx
Window Winder Sealant/Goo: 0.084 kg
Wheels & Outer Trim
Door Handle Chrome Mk3 (each): 0.371 kg
Front Indicator Lense Glass (each): 0.080 kg
Front Indicator Lense Plastic (each): 0.015 kg
Front Indicator Unit with Plastic Lense (each): 0.086 kg
Grille Quick Release Buttons/Fittings: 0.091 kg
Headlamp Ring Trim (each): 0.149 kg
Sill Seam Rubber Trim both sides: 0.370 kg
Washer Jets Chrome Twin Type (each): 0.019 kg
Wiper Arm Complete including Blade (each): 0.110 kg
Wiper Wheelbox Bezels Chrome Including Nuts & Seals (pair): 0.048 kg
Wheel 1275 GT Steel 10” x 4.5” (without tyre): 4.090 kg*
Wheel Cooper S Steel 10" x 3.5" (without tyre): 3.520 kg*
Wheel Cooper S Steel 10" x 4.5" with 165/70 x10" Tyre: 9.000 kg*
Wheel Cooper 12" x 4.5" with 145/60 x12" Tyre: 9.200 kg*
Wheel Nut (chrome): 0.035 kg
Wheel Minilite Alloy 10" x 5" (wheel only): 3.770 kg
Wheel Minilite Alloy 12" x 5" (wheel only): 4.570 kg
Wheel Minilite Alloy 13" x 6" (wheel only): 6.510 kg
Wheel Minilite Magnesium 10" x 6" (wheel only): 2.925 kg*
Wheel Sports Pack Alloy 13" x 6" (wheel only): 6.760 kg
Wheel Stud (each): 0.022 kg
Wheel Stud 55mm for rear brake drum with built-in spacer (each): 0.034 kg
Wheel Super Light Alloy 13" x 6" (wheel only): 5.620 kg
Wheel Super Light Alloy 13" x 7" with 175/50 x13" Tyre: 12.100 kg*
Fresh Air Ducts & Heating
Air Intake Inner Wing Duct (Mk3): 0.170 kg
Air Intake Hose to Distribution Box (Mk3): 0.180 kg
Demister Duct Left Hand Including Screws (Mk3): 0.046 kg
Demister Duct Right Hand Including Screws (Mk3): 0.057 kg
Distribution Box Including Nuts, Washers & Seal (early Mk3 without face vents): 0.249 kg
Heater Box Metal Case (Mk3): 4.4 kg
Heater Matrix (Metal): 1.226 kg
Hose Inner Wing to Heater (Mk3): 0.081 kg
Hose Heater to Demister Left Hand Duct (Mk3): 0.037 kg
Hose Heater to Demister Right Hand Duct (Mk3): 0.037 kg
Electric
Fuse Box 1976-96 (Including the 4 fuses plus 2 spares): 0.081 kg
Headlamp Bowl Inner & Rim Lamp Holder (each): 0.221 kg
Headlamp Bowl Metal (each): 0.270 kg
Indicator Switch Assembly Single Stalk (Mk3): 0.199 kg
Rear Light Unit Mk2 (Including Rubber Gasket): 0.649 kg
Wiring Loom Front Early Mk3: 1.511 kg
Wiring Loom Rear Early Mk3:
Wiring Loom Head Early Mk3 (per side): 0.075 kg
MSA (Motor Sports Association) Minimum Weights for 2012 for Rally Cars
……………….Post 1/1/82………Cars upto 31/12/81……..2wd Specialist Rally Cars
Upto 1000cc…….720 kg………………..655 kg
Upto 1400cc…….840 kg………………..700 kg………………………620 kg
Upto 1600cc…….920 kg………………..740 kg………………………670 kg
Upto 2000cc…...1000 kg………………..810 kg………………………720 kg
Upto 2500cc…...1080 kg………………..880 kg………………………770 kg
Upto 3000cc…...1150 kg…………….….945 kg………………………880 kg
Upto 3500cc…...1230 kg……………….1005 kg
Upto 4000cc…...1310 kg……………….1075 kg
All non-homologated cars must conform to the minimum weights table above. The only exceptions are vehicles that have a specified minimum weight recorded in their MSA Competition Car Log Book.
All homologated cars must conform to the minimum weights stated in their homologated documents.
#107 newenglandmini
newenglandmini
  • 646 posts
Posted 02 January 2014 - 01:24 PM
I was preparing to post a question related to weights to assist in planning a "rollover" of my Mini to allow access to the bottom for restoration purposes.  No need for the posting.  This is brilliant!
#108 Dusky
Dusky
  • 5,322 posts
Posted 19 January 2014 - 08:23 AM
to add: non verto clutch plate (ap-racing)
used(1 year of racing): 579 gramms
unused:570gramms
#109 titus20
titus20
    Starting My Mini Up
  • 1 posts
Posted 24 March 2014 - 05:27 AM
Thanks for sharing that list. This would be help...
#110 Gremlin
Gremlin
  • 2,142 posts
Posted 24 March 2014 - 07:22 AM
My 89 998 weighs 650kg with full tank of fuel
#111 jimmyjjohn
jimmyjjohn
  • 11 posts
Posted 30 March 2014 - 02:23 AM
Ye gods you must have spent some time doing this, i'll put it to the forum team to see if we can pin this.
#112 Dusky
Dusky
  • 5,322 posts
Posted 10 April 2014 - 06:55 PM
whats the waight of a verto flywheel incl pressure plate etc?
#113 miniweights
miniweights
  • 199 posts
Posted 12 April 2014 - 10:54 AM
The Verto flywheel is approx 5.6kg and the pressure plate assembly is 4.8kg.
#114 miniweights
miniweights
  • 199 posts
Posted 03 May 2015 - 06:14 PM
Weights
Kerb Weights:
Van: 605 kg approx
Pickup: 604 kg
Moke: 562 kg
BODY
Bonnet Mk2: 7.7 kg
Dash Card: 0.540 kg
ENGINE
Camshaft A+ 1275: 1.920 kg
Camshaft Follower A+ 1275 Standard (each): 0.046 kg
Crankshaft A+ 1275 (CAM 6232): 11.900 kg
Crankshaft Main Bearing Cap Front A+ 1275 (water pump end): 0.482 kg
Crankshaft Main Bearing Cap Middle A+ 1275: 0.570 kg
Crankshaft Main Bearing Cap Rear A+ 1275 (flywheel end): 0.488 kg
Crankshaft Main Bearing Cap Bolt: 0.060 kg
Engine Block A+ 1275 Bare with Main Bearing Cap fitted: 34.5 kg
Oil Pump: 0.493 kg
TRANSMISSION
SUSPENSION
STEERING
BRAKES
Disc 8.4": 2.906 kg
MISCELANEOUS
Fluids
Fuel System
Engine Bay
Interior
Pedal Box: 2.100 kg
Wheels & Outer Trim
Electric
#115 evansisgreat
evansisgreat
  • 1,103 posts
  • Local Club: Not yet
Posted 19 May 2015 - 07:06 PM
Brake Drum Rear Alloy Finned non Spacer (each): 1.454kg
#116 dutchacme
dutchacme
    Starting My Mini Up
  • 2 posts
Posted 05 February 2016 - 05:56 PM
drive shaft yoke rubber coupling 21A1696 718 grams each
Wim
#117 zebigfatman
zebigfatman
  • 159 posts
  • Local Club: Snowdon minis
Posted 05 February 2016 - 10:01 PM
Well done! Will be refering to this list often to see how much weight I have shed off the car
#118 dutchacme
dutchacme
    Starting My Mini Up
  • 2 posts
Posted 05 February 2016 - 10:33 PM
one rubber drive shaft coupling (crucifix) GCD101 complete with 4 U-bolts and 8 nuts 1055 grams.
Wim
#119 RichardBeattie
RichardBeattie
  • 22 posts
Posted 08 March 2016 - 12:13 PM
Any idea of the weight saving if I fitted fibreglass doors, bootlid and bonnet on a mk3 shell?
#120 need4speed
need4speed
  • 83 posts
Posted 03 February 2017 - 11:21 AM
On the subject of kerb weights, weren't the very early Mk1s made of a slightly thinner gauge steel and therefore had a lower kerb weight. I remember people searching for 59 (and possibly 60) shells decades ago to use in race cars.
