Mini X Flow Enigne
85 replies to this topic
#61 stoneface
stoneface
  • 368 posts
Posted 23 September 2016 - 01:22 PM
lol, my bad the block is the right way round. looked closer and can see the oil pump hole.
#62 stoneface
stoneface
  • 368 posts
Posted 23 September 2016 - 01:26 PM
yes left side machined for starter. Even then the standard one can be a tight fit so I fitted a high torque starter from Brise which has a smaller body.
#63 megamini_jb
megamini_jb
  • 5,491 posts
  • Name: Jamie
Posted 23 September 2016 - 01:28 PM
Gits :P :lol: don't do that to me so early on! Lol
#64 stoneface
stoneface
  • 368 posts
Posted 23 September 2016 - 01:32 PM
Sorry :-)
#65 pogie
pogie
  • 498 posts
  • Local Club: Essex MC
Posted 23 September 2016 - 01:35 PM
I will be following progress with considerable interest.
I assume the intake trumpets will be sticking out the front? Good for collecting air, but also good at ingesting dirt. Or is it going in a Clubman?
The trumpets are not fitted correctly in the picture.  The ridge on the trumpets locate in the recess in the bore of the carb body so they should sit 20-30mm further in so they might fit under a clubman front end.  But there are shorter ram pipes available if they are still too long.
#66 megamini_jb
megamini_jb
  • 5,491 posts
  • Name: Jamie
Posted 23 September 2016 - 01:42 PM
Sorry :-)
I forgive you as you've provided so much brilliant info :-) and no doubt more to come once I get going properly lol.
#67 megamini_jb
megamini_jb
  • 5,491 posts
  • Name: Jamie
Posted 23 September 2016 - 01:43 PM
Yep I only used them for the photo as I already had them in arms reach :P they don't fit my 40s anyway
#68 pogie
pogie
  • 498 posts
Posted 23 September 2016 - 01:56 PM
This clubbie estate was around in the 80s and was featured in CCC.  I haven't seen it for a long while, IIRC it went to Japan.
#69 gazza82
gazza82
  • 3,013 posts
  • Local Club: TMF+
Posted 23 September 2016 - 03:52 PM
I'm confused :P just looking at Lotus Twin Cams and it's all facing the same way as mine?
My bad .. thought is was an a-series block with twinky head .. so that's a Ford engine mated to a mini gearbox ?
#70 Mini ManannĂ¡n
Mini ManannĂ¡n
  • 2,856 posts
  • Local Club: man Estate
Posted 23 September 2016 - 05:40 PM
The pic in question's diskappeared :(
I'm following this adventure :-)
#71 megamini_jb
megamini_jb
  • 5,491 posts
  • Name: Jamie
Posted 23 September 2016 - 06:14 PM
My pic? If so it should still be there :-) working for me.
Thanks, I can't wait! I love A series and none of the other conversions have ever appealed to me, apart from this one, but never thought I'd actually be doing it :D
Edited by megamini_jb, 23 September 2016 - 06:16 PM.
#72 tiger99
tiger99
  • 8,584 posts
Posted 24 September 2016 - 04:39 PM
Pogie, what an amazing picture! Even though I normally dislike Clubmans because to me they just don't look right, I would really like one of those. It just looks so neat and tidy, as if the engine really belongs there.
Not many conversions look right, in fact many using modern engines look as if a blind person just scooped up all the ancillaries and threw them in. Not because of bad engineering in most cases, just because there are an indecent amount of vital bits to find homes for. But the Ford engines, being old, have very little of that.
#73 megamini_jb
megamini_jb
  • 5,491 posts
  • Name: Jamie
Posted 25 September 2016 - 12:24 PM
Can't wait to have the cam cover back.
Still undecided what colour to do the rest. I'm thinking purple block and the rest black.
Edited by megamini_jb, 25 September 2016 - 12:25 PM.
#74 mab01uk
mab01uk
  • 12,413 posts
Posted 16 October 2016 - 10:25 PM
Some more pics of another Mini Ford engine that was on ebay a while back......
#75 tiger99
tiger99
  • 8,584 posts
Posted 17 October 2016 - 11:36 AM
Thanks for these pictures. It shows quite clearly how it was done, largely by a welded fabrication on the end of the gearbox. I thought it might have been bolted on, but what was done gives more crank clearance.
The complete assembly looks very convincing, but slightly on the tall side. I am still thinking about this approach for my next Mini, because a Ford engine would not need a high state of tune and so could be lightly stressed and have a long life. Also fitting modern engine management, with mapped timing and fuelling, is easier with an 8 port crossflow.
