Step By Step Engine Build, No Waffel, Just Building..
#61
Posted 20 November 2012 - 11:59 PM
Hopefully I'll have a chance to follow it in the future.
#62
Posted 05 January 2013 - 03:04 PM
#63
Posted 27 January 2013 - 07:42 PM
#64
Posted 28 March 2013 - 05:31 PM
#65
Posted 18 April 2013 - 03:51 PM
very informative, I shall be building a new engine myself now ive read through this, Thanks :)
#66
Posted 11 May 2013 - 02:00 PM
Great thread Andy, excellent work. I'm planning to extract all of your posts and pictures and compile them into a pdf document so people can print it out and use it as a garage reference. Would you have any objections to me doing this?
Cheers for your efforts in documenting your work.
#67
Posted 15 May 2013 - 04:42 PM
Thanks for the nice comment...But I want this info to be exclusive to the forum please. It was done so that people on this forum could reference it when building engines. It is not a professional guide and should not be used or offered as such.. There are lots of books and videos out there on engine building for anyone who wants a proper guide.
Thanks.
Andy
#68
Posted 31 May 2013 - 09:03 AM
Looks tidy....hope it all goes well!
#69
Posted 01 July 2013 - 04:29 AM
In relation to the addition of the adjustable cam sprocket timing gear, are there any alignment issues or do you just bolt them on.
Cheers?
#70
Posted 11 July 2013 - 06:56 AM
#71
Posted 11 July 2013 - 07:08 AM
#72
Posted 07 September 2013 - 02:19 PM
Andy thanks so much for this! Quick question and it'll probably sound awfully obvious but how do you recommend stripping and repainting the block and head?
#73
Posted 27 November 2013 - 04:02 PM
I used a parts washer to get all the grease and old oil off then a wire brush on the drill to remove all the old paint. then back into the parts washer for a really good scrub. you really need the oil plugs and core plugs removed to get the gallery's totally flushed out. Lastly once its completely dry, I blast everything with the air hose to remove any lingering bits if grit or dirt. Once the paint is on and dry you need to clean it all again. time consuming I know. but well worth the effort. Finally I oil everything up before the assembly starts!!
Good luck and thanks for reading.
Andy
#74
Posted 02 February 2014 - 11:22 PM
Apart from cleaning the inside of the breather out, is there a benefit of modifying the breather? I'm assuming it's for clearance, but what's it for clearance of?
H
#75
Posted 21 February 2014 - 09:12 PM
Brilliant thread, will be refeering to it in the future since I have a 1275 to strip down and rebuild!! Am actually trying my hand at porting currently the into the local engineering works for new guides and skim!!
