Mini Stance
#1141
Posted 11 October 2012 - 08:48 PM
#1142
Posted 12 October 2012 - 06:47 AM
#1143
Posted 12 October 2012 - 06:49 AM
#1144
Posted 12 October 2012 - 02:43 PM
How did a bearing going result in your wheel flying off?
Looks like the nuts weren't tight enough? The studs are still there?
#1145
Posted 12 October 2012 - 04:40 PM
Thought the same two at first wasnt just the bearing the hubs had to be changed to. tightened every thing up and cheked the Studs/ bolts ect. went for a test run round the block and heard a load nocking noise. as i said bearing and hub had gone so prob couldnt cope with the wight and the spacers.
#1146
Posted 12 October 2012 - 05:46 PM
I'm not doubting you had trouble, but when people say "spacers / large wheels accerelate bearing wear" it isn't exponetial, you don't fit them and your car explodes. If it does, there's something else involved.
#1147
Posted 15 October 2012 - 06:51 PM
I'm not to sure on the below one because of the camera angle?
#1148
Posted 15 October 2012 - 10:14 PM
Ooooo
#1149
Posted 15 October 2012 - 10:18 PM
#1150
Posted 16 October 2012 - 02:45 PM
Edited by jb93, 16 October 2012 - 02:45 PM.
#1151
Posted 16 October 2012 - 03:54 PM
Check this;
#1152
Posted 16 October 2012 - 05:03 PM
you call that neggy camber?
Check this;
#1153
Posted 16 October 2012 - 05:43 PM
Ugh.... why can't I like this more than once?Neggy camber
#1154
Posted 16 October 2012 - 05:48 PM
I'll post it again if you like?
mmmmmmmmm neggy camber
Edited by jb93, 16 October 2012 - 05:49 PM.
#1155
Posted 16 October 2012 - 06:02 PM
I think once more would be pushing my luck a little
