Unless you do some serious work to address it: http://www.minipicku...tart=555#p20823
Mini Stance
#3301
Posted 10 September 2015 - 07:45 AM
#3302
Posted 10 September 2015 - 09:59 AM
Amazing how you can ride it sitting so low.. Do you think that with adjustable shockers one can get the car to stay even lower?
Looks sick Matt!!
What size wheel you running?
Still trying to figure out what and how I'm going to get that look with my 10"'s.
They are 13x7 currently but I am going to get new dishes made for them to take them to 13x8 at the rear and 13x7.5 at the front
That looks awsome, what's the set up in terms of suspension do you have?I tubbed my arches and added some rear camber brackets to add some more stance! Got some plans to add some more lows as well as adding front camber and getting some wider dishes made for the wheels to improve the fitment all round
[/url]
Opinions?
There is nothing special about the suspension at the moment, it is just hi-los, camber brackets and tubbed arches but as I mentioned I've got something planned to take it lower which will mean completely changing the suspension
I have hi lows and camber brackets but i can't have the car that low
To go lower static you would need to fit a kit like what minitastic offer or cut the bump stops out but if you use it daily like me that's a big commitment which is why I'm looking at other options
Haha thanks man, they are force racing turbo TF wheels
Seen as that people are liking it here's another snap
[URL=http://s1276.photobucket.com/user/Dominic_Mattholie/media/D9E9DFCD-7ACD-4444-9C26-CE09C0663169_zpsglfvprj8.jpg.html]
What kind of options? My car is for me to drive whenever i want, so i'm looking for something that can give me a harder suspension. I only have hi-lows and stock shock absorbers, do you think that GAZ adjustable ones can provide a harder suspension and allow me to lower the car a little bit?
#3303
Posted 10 September 2015 - 02:13 PM
When you start getting properly low you'll run into issues with the top ball joint binding up and snapping
This is my concernwhen going lower than I am. No way round it as far as I can see if going static. Air ride you get for Minis is bulky and the lower arms you see in some kits are a bit 'backyard' in appearance.
#3304
Posted 10 September 2015 - 05:41 PM
This is my concernwhen going lower than I am. No way round it as far as I can see if going static. Air ride you get for Minis is bulky and the lower arms you see in some kits are a bit 'backyard' in appearance.When you start getting properly low you'll run into issues with the top ball joint binding up and snapping
Well I may be able to let you know what it's like next year...
#3305
Posted 12 September 2015 - 06:11 PM
Excellent, that is exactly what I'd planned on doing once I pick up a spare twin bolt subframe to modify. More than likely going to remake my top shcok mounts yet again to get a better angle of operation on the coilovers and some travel.
#3306
Posted 24 September 2015 - 09:38 PM
Looks a good idea, can you still get to the pin nut easily at the back with the subby in the shell?
Edited by jonny f, 24 September 2015 - 09:38 PM.
#3307
Posted 25 September 2015 - 07:05 AM
#3308
Posted 11 October 2015 - 07:11 AM
#3309
Posted 11 October 2015 - 11:16 AM
I've prob asked 100 people about what flares they have....... But what flares are these?
Edited by mini-fvr, 11 October 2015 - 11:19 AM.
#3310
Posted 11 October 2015 - 06:03 PM
99% Sure they a miglia arches that have just been trimmed down to fit.
#3312
Posted 15 October 2015 - 05:35 AM
You could tub the rear arches to get it down a little lower.... but love the look of your it would be a shame to start chopping ....
#3313
Posted 15 October 2015 - 11:10 AM
Raise the front so it's level with the rear, and it'll be useable and look cool still.
#3314
Posted 15 October 2015 - 12:02 PM
I was thinking of having 3mm shaved off my rear "spacered" drums, to pull the wheel in a hair. Anyone ever try that?
Edited by mini-fvr, 15 October 2015 - 12:03 PM.
#3315
Posted 15 October 2015 - 10:13 PM
Looks sick like this, I'd leave it with that to be honest. I tubbed my rears and always wanted to go lower, but now i wish i had the sort of stance you have.
5 user(s) are reading this topic
Bing (1)
