Mini Stance
3581 replies to this topic
#2131 Jayme 1275
Jayme 1275
  • 488 posts
Posted 13 May 2013 - 03:50 PM
7x13 superllites, midland wheels sell them
I dont think they're Superlights. The spokes end too soon. On superlights they go all the way to the dish. It could just be the angle though!
they are not 7x13 superlites. It is a 13 inch wheel but if u look closely the spokes look much bigger (not the angle of the photo) and has got only a small dish. Those wheels will be ideal for my mini wit the watson frame because of the less dish offset
13X8 minilites according to this for sale advert -
http://www.motorspor...cars/18426.html
I believe alot of info can be found about this car with a simple google search of 'Z cars vtec mini carbon' - I'd search abit harder but im at school at the minute :gimme:
ahh crap they found out to be ford wheels! then i need to modify my hubs >_<
Yea you could hit a problem there, if you drill the hubs youl then have to find somewhere to put the splines in it.
id probably think you would be better drilling the wheels.
Or you tap a thread into the drilled hole in the hub and use a wheel bolt.
yea but will you have enough clearance on the side of the disc center. i know on later cars anyway you need to remove the flange to replace the nuts and they aren't overly big on the o/d
so the problem you may have is you can re drill and tap them but when it comes to tighten the bolt it may make contact preventing it from turning, which in return would mean you wouldn't be able to to tighten it enough.
#2132 RayBoogs
RayBoogs
  • 1,109 posts
Posted 14 May 2013 - 08:02 AM
Yeah thats a possibility. I was just throwing ideas around. I think you could re-drill and tap a thread with some though, you could probably spacer out the wheel to give you the clearence to tighten the wheel down.
Re-drilling the wheel is easier, but it looks bad. You could always make some adpaters.
#2133 Tupers
Tupers
  • 4,176 posts
Posted 14 May 2013 - 09:29 AM
Or you could just get them direct from Minilite with the correct PCD.
#2134 IainNeon91
IainNeon91
  • 1,288 posts
Posted 14 May 2013 - 01:59 PM
Fitted my rear hi los yesterday, wanted to see what my mini would look like lowered... Luckily my mini sits with the correct amount of camber so my wheel clears the 'lip' of my group two's
Iain.
#2135 DylPhil
DylPhil
  • 112 posts
  • Local Club: MOWOG
Posted 14 May 2013 - 07:10 PM
**** thats nice
#2136 Harryweekes
Harryweekes
  • 50 posts
Posted 14 May 2013 - 07:46 PM
#2137 IainNeon91
IainNeon91
  • 1,288 posts
Posted 14 May 2013 - 07:52 PM
Can you drive it that low?
#2138 adam_93rio
adam_93rio
  • 3,271 posts
Posted 14 May 2013 - 08:09 PM
If you can look under and see a glimpse of daylight at sunrise then you can drive it
Edited by adam_93rio, 14 May 2013 - 08:09 PM.
#2139 Harryweekes
Harryweekes
  • 50 posts
Posted 14 May 2013 - 08:13 PM
just about wouldnt like to take a corner fast that low ive raised it since this photo, also it didnt like speedbumps this low
#2140 IainNeon91
IainNeon91
  • 1,288 posts
Posted 14 May 2013 - 10:31 PM
Don't you have to have like 'lowered' type adjustable shocks first?
#2141 adam_93rio
adam_93rio
  • 3,271 posts
Posted 14 May 2013 - 10:45 PM
I ram mine pretty low on standard shocks with little movement left in them for a while, I think the mini suspension being quite stuff anyway helped. But people wanting their cars really low and then expecting them not to scrub or scrape from time to time are daft to be honest
#2142 IainNeon91
IainNeon91
  • 1,288 posts
Posted 14 May 2013 - 10:50 PM
" But people wanting their cars really low and then expecting them not to scrub or scrape from time to time are daft to be honest " - adam_93rio
True statement bro
#2143 RayBoogs
RayBoogs
  • 1,109 posts
Posted 15 May 2013 - 07:45 AM
Well that would be the easy way.
Edited by RayBoogs, 15 May 2013 - 07:46 AM.
#2144 Driezzie
Driezzie
  • 662 posts
Posted 15 May 2013 - 09:46 AM
Lainneon91 you sticker ******* :D !!!
#2145 IainNeon91
IainNeon91
  • 1,288 posts
Posted 15 May 2013 - 10:12 AM
Damn Keyboard making it look like the 'i' at the beginning of my name is an 'L'  :mmkay: haha My name is iain not Lain  :lol:
I want to know the word underneath those stars! haha, but yes i do like a sticker or two  :shifty:
