Halfords battery charger
9 replies to this topic
#1 MiniSi
MiniSi
  • 350 posts
Posted 05 February 2006 - 11:45 PM
Any idea how long, on "Normal" speed, it takes to charge a car battery?
#2 minidaves
minidaves
  • 4,933 posts
  • Local Club: mine
Posted 05 February 2006 - 11:47 PM
yep i have one it depends how flat it is
dave
#3 MiniSi
MiniSi
  • 350 posts
Posted 05 February 2006 - 11:59 PM
I'm not totally sure Dave. When I connected it up the lights on the dash were quite faint.
I'm going to see how it is tomorrow morning :w00t:
#4 Modmobile
Modmobile
  • 601 posts
Posted 06 February 2006 - 09:30 AM
We've got one, dunno if it's Halfords though. It was usually okay if we left it on charge overnight (Rover with dicky alternator :w00t: )
#5 minilady
minilady
  • 49 posts
Posted 06 February 2006 - 09:47 AM
Does your charger have a meter to tell you how much current it is putting out?
If battery is rated at 35 ampere-hours, it should theoretically deliver power for at least 35 hours at 1 amp, 17.5 hours at 2 amps, 7 hours at 5 amps etc.
Charging is less efficient, so a cmpletely flat battery would take more than 35 hours at one amp to fully charge it. But if your battery is capable of lighting a lamp, it's not completely flat, and you can use (amp-hour rating divided by charging current) to estimate charge time.
With most chargers, the current drops as the battery charges.
If charger has no meter, I'd guess it delivers up to 5 amps into a flat battery, dropping to 1 or 2 amps after an hour or so, then down to 1 amp or less as the battery reaches full charge.
If you have a voltmeter, a fully charged battery should read around 14 volts with the charger switched off. Or you could look for the gassing and temperature rise that happens at the end of charge.
#6 gsms
gsms
  • 2,285 posts
Posted 06 February 2006 - 12:20 PM
I just leave mine on over night and its fine by the morning.
Si, if yours isnt working I can pop mine round today/tomorrow?
Guy.
#7 MiniSi
MiniSi
  • 350 posts
Posted 06 February 2006 - 12:52 PM
mines f**ked mate for want of a better explanation. lol.
#8 Bounce
Bounce
  • 2,197 posts
Posted 06 February 2006 - 01:02 PM
If your battery is comnpletely flat, check the electrolite levels, If its a sealed battery dont worry about them. If your electrolite levels are low you can refil them with lightly salted water, fill it you so it covers all the plates inside.
But i'd highly recomend buying a new battery, it will hold its charge longer than a battery that has been fully discharged.
#9 MiniSi
MiniSi
  • 350 posts
Posted 06 February 2006 - 01:12 PM
Hi bounce. Thanks for your helpful advice in this and the other thread of mine. With regard to the battery its brand new and I flattened it in the old car. I've left it on charge and its going ok so will see how it goes :w00t:
#10 Bounce
Bounce
  • 2,197 posts
Posted 06 February 2006 - 01:18 PM
No worries buddy
