I have just started racing mini 7's out here in New Zealand and we are running Hoosier Slick racing tyres.
ever since we started, we've been given so much advice from people it's scary!
we went on the basis of listening to the boys who are racing at the front, who run 2 degrees negative camber all round, and the tyre pressures hot 30 psi, (starting with 24 psi cold fronts, and 26psi cold rears)
however, i contacted Hoosier in america, and they recommended;
Start your cold pressures at FRONT(17 – 19 psi) and REAR(14 – 16 psi). After a 20 minute track session, your HOT pressures should be FRONT(22 - 24 psi) and REAR(19 – 20 psi). Camber settings in the front should only be -1.0 degrees to -1.5 degrees.
From this information what would you all recommend?
do i try changing all my settings to this instantly and go and try it? or change certain things slowely? or ignore it all together and do whatever all the other racers are doing?
Finally, what is a good way of checking if the settings are working? apart from lap times, what else should be happening? i've heard about using a thermal sensing gun to check temperatures across the tyres? ie hotter on the inside due to camber ect.
Advice from anyone with knowledge or there own opinion would be good,
thanks
Nick
