Jack Knight Gearbox
Posted 15 November 2011 - 11:27 AM
I usually switch off the engine, put it in reverse and start up. Do a bit of reversing and the gears go back to normal as if nothing happened. My mechanic hasn't a clue as to what it could be.
Has anybody encountered this problem?. It seems to happen occasionally when I select reverse from a cold start.
Thanks in advance.
Posted 15 November 2011 - 11:49 AM
Posted 15 November 2011 - 01:56 PM
Posted 15 November 2011 - 02:33 PM
Posted 15 November 2011 - 03:20 PM
Posted 15 November 2011 - 03:42 PM
Posted 15 November 2011 - 03:48 PM
Posted 15 November 2011 - 03:51 PM
Posted 15 November 2011 - 03:54 PM
Posted 15 November 2011 - 04:04 PM
However, I remember him fitting a used clutch master cylinder and as you guys remarked it's possible that it requires a bit more bleeding. What a relief i must say. Thank you all once again.
Posted 15 November 2011 - 04:45 PM
Yes they do .................http://www.jackknight.co.uk/
There not the 'same' jack knight of old... They own the name but... Best you all read this thread fron the begining and make your own minds up.
The very last post is the most important IMO.
http://www.ten-tenths.com/forum/showthread.php?t=105445&page=4
Posted 15 November 2011 - 06:23 PM
Posted 15 November 2011 - 06:27 PM
Posted 15 November 2011 - 06:42 PM
Not sure why you would want a JKD, or copy of, gearset anyway....
Posted 15 November 2011 - 06:45 PM
