1100 8V Metro Engine Question
Posted 14 November 2011 - 11:01 PM
Is there a subframe available for this engine?? or how would i modify a mini frame to suit the engine??,
any advice, pictures or measurement would be very helpful
Thannkyou Aaron
Posted 14 November 2011 - 11:09 PM
Edited by samsfern, 14 November 2011 - 11:12 PM.
Posted 15 November 2011 - 07:05 AM
Any frame you use you can swap the engine for a bigger model at a later date as all Kseries are the same dimentions from the 1.1 though to the 1.8vvc although the 8v shoud be easier as the head is half the size.
Have a look though the build diaries for some idea how much work is involved.
Posted 15 November 2011 - 07:17 PM
but i am thinking of converting to clubman front.
Any chance or does anybody know where i could find good photographs and diagrams of a modified mini frame, as well as measurements and dimensions as fabricating one wouldn't be to much of an issue?
Posted 15 November 2011 - 07:36 PM
Posted 15 November 2011 - 08:24 PM
Newer build with a better frame
http://www.theminifo...howtopic=202355
My original build
http://www.theminifo...opic=30791&st=0
Posted 15 November 2011 - 08:35 PM
Just a thought.
Posted 15 November 2011 - 09:02 PM
Posted 15 November 2011 - 09:22 PM
Also comes with a 5speed box
Posted 15 November 2011 - 10:04 PM
Also how do you rate the rate the rover 1400 8 valve ?? good or bad ??
Posted 15 November 2011 - 10:31 PM
Edited by samsfern, 15 November 2011 - 10:34 PM.
Posted 15 November 2011 - 11:33 PM
I had another Mk3 Metro which I bought with a months MOT, it was a 1.1 8v and again a very strong engine, good fun to drive.
My red Metro will soon be receiving a 16v 1.4 K-series with 5 speed box, and eventually a VVC. The type B gearbox has a LSD.
You can get lots of power from all of the K-series for very little money at all. I know of low 13 second 1/4 mile Metros that have been built for under a grand
Edited by Mini-Mad-Craig, 15 November 2011 - 11:35 PM.
Posted 18 November 2011 - 10:36 AM
Is it necessary to chop out all of your inner wings when fitting the conversion??
Posted 18 November 2011 - 01:16 PM
http://www.16vminicl...ead.php?t=26628
Posted 29 November 2011 - 07:09 PM
And is a metro frame a straight fit or does any modification have to be made to the frame??
