How do I take off the black air vents that are to the far left and right of my dashboard, i have water coming in from that area and want to investigate exactly where it is coming from?
Air Vents On Dashboard, How Do They Come Off?
fourwheels
, Nov 13 2011 12:23 PM
3 replies to this topic
Posted 13 November 2011 - 12:23 PM
Posted 13 November 2011 - 12:26 PM
the outer ring that sits around them just twists off. can be slightly tricky if they're really tight but they should come off okay
Posted 13 November 2011 - 01:58 PM
What style of dash?
The shiny ring is on a screw thread, if it has a parcel shelf, the cone shaped bit of plaggy will pull off once the ring's removed and the actual vent underneath has a twist'n pull type socket. The bit you really need to get at is weld to thebody with 4 screws.
Posted 13 November 2011 - 03:09 PM
cool thank you that worked really well.
