F1 / Wrc /a z cars monte carlo
PROJECT RAPID!!!!
#256
Posted 23 December 2006 - 04:07 PM
#257
Posted 23 December 2006 - 05:19 PM
#258
Posted 23 December 2006 - 07:40 PM
#259
Posted 28 December 2006 - 02:44 PM
The dash that eddie was to make for me was 2x2 twill 200g carbon fibre with z-cars logo embossed into the left hand corner. Now that not going to happen i was thinking of maybe having it coverd in suede to match the wheel.
Mark how much was it to be covered? The finish of the dash is a bit tatty you see
DSC00022.JPG 200.38K
1467 downloads
DSC00023.JPG 183.01K
44 downloads
DSC00024.JPG 183.11K
33 downloadsSC00024.JPG]
#260
Posted 28 December 2006 - 02:50 PM
#261
Posted 28 December 2006 - 03:09 PM
100_0188.jpg 208.42K
40 downloads This shows how much was removedNo Eddie supplied Chris at zcars i think, i just got chris to send 1 down
#262
Posted 15 January 2007 - 08:03 PM
"Initially we expected to complete the items made to order within 10-12 working days,
Due an unusually huge increase in orders during our Christmas break in the period of 22/12/06 to 08.01.07 has caused a backlog of orders and has pushed our normally excellent lead time to longer than normal.
The order should ship to you in the next 5-7 days.
I apologise if this may take longer than excepted.
Furthermore:
Due to our rapid expansion we are having building work at our offices from 15/01/07 until 30/01/07 during this time we will be completely out of action, and unable to receive emails, or process any orders or enquiries, your order should still ship to you as normal during this time."
grrrrrr why i orta!
Apart from that not much has gone on. Had a bit of a tinker on the lathe the other day and turned down the oil swith sandwich plate down so it doesnt foul on the case channels and now sits a few more mm away from the zaust.
I had a bit of difficulty getting the plate to fix tight in the jaws. I had just a few mm to attatch it so the first go went a bit pair shaped. The jaws were set internally and being a bit eager to finish i took too much at a time off and the plate got hot....... causing it to loosen and mess up the line. Took my time towards the end and straightend everything out!
looks the part now. Wooot!
hhhhhh.jpg 13.1K
18 downloads from this.....
DSC00068.JPG 343.57K
27 downloads set up on lathe and thinned
DSC00069.JPG 318.07K
18 downloads shoulder being removed
Picture_136_modified.JPG 146K
23 downloads
Picture_137_modified.JPG 88.04K
26 downloads Also you can see from the above picture how much was taken off this side of the plate making it thinner so i can remove the filter without removing the exzaust! I will also have to take a little off the centre fitting which was too long anyway
Edited by dean_chad, 16 January 2007 - 06:58 PM.
#263
Posted 08 February 2007 - 06:09 PM
DSC00014.JPG 276.39K
32 downloadsI also tried the sandwich plate in for my pressure switch and maybe the temp sensor. I think there is more than enough room so damage from heat wont be a problem. With the heat wrap around the exhaust added i dont think i will have any problems with high oil temps. I can also change the oild filter without removing the exhast system, wehey bonus! I will have to weld up 2 of the blank holes so that i can have the remaining holes can be positioned so they wont fowl on anything.
DSC00017.JPG 264.93K
27 downloads
DSC00093.JPG 257.71K
25 downloads
DSC00018.JPG 273.4K
27 downloadsSC00018.JPG]Ive just put the exhaust on to show how close it it. With the gaskets in the header and the muffler attatched i think there will be a little more room than you see here. Still seems enough though
#264
Posted 13 February 2007 - 08:45 PM
so much progress has been made since i last looked
top marks
#265
Posted 26 February 2007 - 08:42 PM
I havenbt looked at your pages for a while sorry to hear about the eddie carry on i think i was luckey although i didnt get the mk2 dash i was supposed to get in the end:(I feel your frustration though!
I am going to start a Z cars project within the near future thats for certain!I hope ya dont mind but the vents on the side look amazing how sis you manage to do them and any change of a few behide the scence pics as i would love to do some thing similar as i think it look great and shuld help performance to an extent.
Cheers Phil
#266
Posted 26 February 2007 - 11:27 PM
#267
Posted 27 February 2007 - 06:34 PM
Yeah im hoping it will help a little with cooling but ive other ideas for forced air (pics coming soon on that). If you look back at the start of the thread you can just about see the side air vents in the very first pics already there when i bought the shell. In fact thats the only reason i bought it (ebay bargain) .... The car was originally going to be a twin engine and he had spent some time on these. The vents were cut out with a plasma cutter so has a very quality finish, the the side where folded in and joined with sheet metal and tacked in place he had spent time smoothing them off although they need a little more. i cant take credit for the work however i will be reeping the benifits of someone elses hard work hehehe!!!
cheers flappy. i wanted to have a go at a few things to see if they work or not!!!
Spent time on the weekend fitting the front brakes and cooling system. See if you can spot what was wrong with the calipers in a couple of the pics ( its been sorted before you ask)!
Itheing it looks really smart with the brake disk cover on what do you recon?
DSC00033.JPG 312.19K
86 downloads
DSC00025.JPG 279.78K
60 downloads Pics showing with disk cover
DSC00034.JPG 268.75K
68 downloads and without disk cover!!Front part of the coolant system, I routed the lower rad hose through the small corner gap in the frame and the top rad hose diagonaly across the back of the tank. I wanted to have the hoses that attatch to the rad at the same angle. think it looks good that way
DSC00031_MODIFIED.JPG 161.51K
66 downloads
DSC00032.JPG 325.37K
78 downloads
DSC00030.JPG 242.13K
61 downloadsIve Just got my gear selector lever. Ymaha wanted £100 for a little bit of metal! that trusty auction site helped again! Wjilst trying to attatch the linkage i noticed it was way too short. Has anyone had this problem and had to make up some kind of bracket? ive put the cable to its absolute adjustment but it still seems way to short.
DSC00036.JPG 247.9K
61 downloads See what iu mean? this pics showing cable at largest adjustment and still the gear lever doesnt fit where the original does. Have i done something wrong or am i just being thick!!?Attatched the throttle cable too. Do you have to use the original cable mount on the engine as it sticks up a fair old way? Has anyone had a go at moving the bracket? Possibly to much work just for a cosmetic thing aye?
cheers people
Dean
p.s if you didnt find what was wrong check the second pic down, i built up the calipers the wrong way so the bleed nipples were facing down! yeah i know, idiot!
Edited by dean_chad, 27 February 2007 - 06:37 PM.
#268
Posted 27 February 2007 - 07:41 PM
- i see what u did too, you've split ur calipers then got the halves mixed up when you put em back together
#269
Posted 27 February 2007 - 07:57 PM
Anyone had the gear link cable problem?
Edited by dean_chad, 27 February 2007 - 10:09 PM.
#270
Posted 02 March 2007 - 07:05 PM
DSC00039.JPG 177.23K
58 downloads
DSC00047.JPG 184.58K
104 downloads
DSC00045.JPG 192.32K
64 downloadsI opted for the special order dash which cost a lil more as Bright blue led cost more, Could have been fleeced with that but worth all the money. Also got them to mill the dash as a steady hand is needed with a dremel, something i dont have after a night out on the sherberts!!! Also in the box was an extended loom, way too much but the wire will come in handy
Cost of carriage and milling cost more than the dash!! Yet another lesson learned for next time..... seem to be learning all this the hard way >
