PROJECT RAPID!!!!
#181
Posted 18 May 2006 - 09:12 PM
#182
Posted 18 May 2006 - 09:19 PM
I found I needed to shim the slave cylinder out so the push rod wasn't at a silly angle... I don't think the subframe bracket is exactly right. You can just see the adjuster nut on the stud, the bit of pipe over the stud disapears most of the way into the slave cylinder.
You can also see the extra return sprin, the plastic conduit over it is to stop it chewing the slave cylinder rubber end cap.
hope that helps.
Digs
YAMAminiR1
www.geocities.com/drusling
thanks lads dont supose you have any piccies? cheers
Posted 18 May 2006 - 09:44 PM
#184
Posted 19 May 2006 - 07:53 AM
Digs
YAMAminiR1
cheers digby.. just had a good look through your site thats really helpful too although the bodywork section on the mini buld doesnt open are you aware of that? could just be my computer!
#185
Posted 19 May 2006 - 05:36 PM
cheers
#186
Posted 19 May 2006 - 05:49 PM
It is a standard mini aeroquip hose from minispares. I modified my slave to reduce the piston movement, otherwise if you pump the pedal a few times you will destroy the clutch mechanism and cover (like i did!!).. Not a problem with a bike as your hand isnt anywhere near as strong as a hydraulic system!!!
Also a good idea to fit a strong return spring so it comes back quickly when you take your foot off the pedal. Some people double up on the internal spring plate to give more feel etc but mine seems fine.
#187
Posted 23 May 2006 - 09:07 PM
what did you do to modify the slave cylinder? I haven't knackered my mechanisim yet, but now I'm worried something might break with an over heavy foot sometime.
Digs
Dean
#188
Posted 24 May 2006 - 07:31 PM
#189
Posted 24 May 2006 - 10:08 PM
Digs
You need the slave type with a circlip in the end. I made up a spacer tube (~15mm long, thickwall) and put it inside the slave after the piston. You can also fit a stop on the engine clutch lever but a bit trickier.
#190
Posted 25 May 2006 - 07:15 PM
#191
Posted 28 May 2006 - 05:15 PM
#192
Posted 31 May 2006 - 04:42 PM
also went on a caterham day yesterday heres the video take a look
my attempt at drifting! funny i know!CLICKY
Edited by dean_chad, 13 July 2006 - 08:58 PM.
#193
Posted 02 July 2006 - 01:55 PM
#194
Posted 05 September 2006 - 11:57 PM
i keep meaning to pop round but i've lost your number can you pm it to me again?
giz
#195
Posted 06 September 2006 - 06:29 PM
well been waiting for special parts for a few months now and also had to pay for my hols, just got back on friday mate. nothings really happend with it. bit gutted really but now hols over im gonna crack on with it. next stop sell my car and buy the engine!!
defo not bored of it just really frustrated , really want to be driving it. i knew it would slow up a few month when it came to buying the engine and digi dash. wont b long now!
The only be ive done is stripped down the servo, and cleaned it up like new. yeah come round on a sunday if you like as every other day i work
dean
