PROJECT RAPID!!!!
#166
Posted 23 April 2006 - 06:19 PM
have you got a front end yet?
i know col's mini's in feckenham have got a couple for sale.oh and as for the handbrake you pm'd me about.. nope sorry scott aint got one either but try col's he'll defo have one.
giz
#167
Posted 23 April 2006 - 07:44 PM
#168
Posted 23 April 2006 - 07:55 PM
#169
Posted 23 April 2006 - 08:12 PM
#170
Posted 24 April 2006 - 05:01 PM
#171
Posted 24 April 2006 - 05:21 PM
#172
Posted 25 April 2006 - 09:01 PM
oh has he now? what condition are they in mate?
sorry i didn't get a good look at them, they looked used but that'll be reflected in the price! col's stuff is cheap as... i got an ally tank for £25!
#173
Posted 27 April 2006 - 12:44 PM
top job though its looking really good/fun at the moment
wayne
#174
Posted 27 April 2006 - 08:21 PM
im considering making the roof scoop, this is the kind of idea im thinking of to force ait to the back got the car. i first thought to use a small scoop at the front then use a channel inside the car but the role bar caused a problem and also headroom is an issue as we all know!!! i decided a channel over the top of the car like the lotus elise would be ideal
this is no the finish size.... maybe have it narrower
hey cardboard is light, sod it i will just tape it to the roof!!!!!
#175
Posted 27 April 2006 - 08:30 PM
Do you mean the Exige?
It all looks really good, even in primer grey.
#176
Posted 17 May 2006 - 07:43 PM
ive been doin a bit of saving nearly ready for the engine.
Ive also been thinking lately to all the bike lads.... is the clutch set up the same as the hyabusa on the video using the hydraulic cylinder etc cheers
#177
Posted 17 May 2006 - 08:10 PM
I can only comment on the R1 clutch, but basically it uses a standard mini master cylinder and a standard mini slave cylinder. The only mod required is to the clutch actuation lever on the donor engine/gearbox, which Chris will do for you if you post it up to him. This mod amounts to a bit of threaded bar welded to the end of the actuation lever, which is then fed inside the slave cylinder to act as a pushrod.
There's no need to limit the amount of clutch pedal travel, as is necessary with the busa setup, but you do need to fit 1 or 2 hefty slave return springs.
Hope this helps, and good luck with the forthcoming engine purchase.
D.D.
#178
Posted 17 May 2006 - 09:45 PM
I added a length of tube that was just big enough to slip over the threaded bar, along with an adjust nut on the bar, makes a simple clutch adjuster....makes it really easy to set the clutch up just right.....just my 2 penneth
Diggers
YAMAminiR1
Dean,
D.D.
#179
Posted 18 May 2006 - 06:05 AM
#180
Posted 18 May 2006 - 08:19 PM
