Saloon Conversion To Another Form Of Mini... Possible?
Posted 10 November 2011 - 06:58 PM
Posted 10 November 2011 - 07:02 PM
Posted 10 November 2011 - 07:45 PM
i think it would be quite an interesting build once the original shell was jigged up and all panels would line up as it should to achieve a factory look...
Posted 10 November 2011 - 08:09 PM
I personally dont see the point in doing it as you may aswell buy an estate/van/pickup to restore in the first place
Posted 10 November 2011 - 08:24 PM
Posted 10 November 2011 - 08:47 PM
its possible yeah, although u would have to source a roof for the estate/van as you cant buy them new and i dont think u can buy the rear C pillars new either so you would either have to cut from a scrap shell or something like that
but yeah its possible
over here their not commonly sold... i'm not a fan of most of the kitcar conversions to date so just thought of it as a conversion of interest and possibly a personal achievement... maybe its a mad thought
i'm sure a roof skin could be moulded in grp from an origional...
Posted 10 November 2011 - 08:49 PM
Anything is possible, if you have the time and money.
plenty of 1 and none of the other just the wrong way around.... loads of time and loads of thoughts
Posted 10 November 2011 - 09:18 PM
As for van/estate if you can locate a roof and complete sil to roof quarter panels nos you might be able to get away with it, however you can buy van load floors, you can't buy estate load floors that I know of so a van would likely be easier then an estate by alot.
Nice thing is if you have a solid floor in the saloon you can just buy the floor extension piece that the factory used to extend it to the longer style.
Pup is definitely the easiest conversion currently, I am trying to do one myself, but basing it off a rotten estate shell I acquired.
Chris
Posted 10 November 2011 - 09:55 PM
the rest is the same
Edited by R.S.P, 10 November 2011 - 09:56 PM.
Posted 10 November 2011 - 10:02 PM
I didn't do it as the Pick-up I had was so original and low mileage. Was great once finished and I eventually sold it to a good friend.
Posted 11 November 2011 - 02:49 PM
Posted 11 November 2011 - 03:36 PM
IIRC, maybe a couple of years ago now in Mini Mag, the cover car was a white saloon that had two rear opening doors, and I think it was a lovely red interior. It was a gorgeous looking car and the two rear opening doors suited it so well. I believe a fair amount of money went into the build and it was worth it, in my opinion. Very good looking and pretty unique.u could make a saloon based pickup and quite a few have been done, but obviously the estate/van/pickup are longer wheelbases than the saloon so cant be converted. I suppose u could do a saloon van aswell, like the fiesta vans u can get but u would have to have a rear opening door, although u could probably incorparate the rear doors from the van/estate into the saloon shell if u know what you are doing
I would have to say though, although I can see the appeal of attempting to extend a saloon and build something else from an engineering point of view, I can't really see the point for any other reason. Surely it would be better to save a rotten standard pick-up or van before it gets so bad it can't be saved.
Posted 11 November 2011 - 05:06 PM
It depends if you can get all the panels. If not you could always make a panel to fit but would not be easy.
Posted 11 November 2011 - 05:36 PM
It would be better to save a rotten pickup, but it seems to me that it will cost twice the price or more to save a real one, even rotten pups in the states are going for several thousand, I got my wagon shell for $600, and it needs floors, quarter panels, nose... same things I would expect to replace on a rotten pickup.
Chris
Posted 11 November 2011 - 06:58 PM
she's a 91 cooper shell and needs alot of panels but the way i see it she's still being saved. i'm not looking to build an exact replica of a derivitive but something i'll enjoy using. i was thinking a van/estate because i was going to build an sr20det powered mini and fancied the extra wheel base but was only a thought... think i might go with either a pickup or hornet instead because of lack of resources with regards the others... it will probably end up a track day weapon but by scratch building you can do what you want with it which is the main apeal i think
chris, you have my interest mate. the conversion you are doing, are you much into it?
