4Wd Rover K Series?
Posted 09 November 2011 - 01:33 PM
Just been looking around on the net looking at the Minitec conversion for a 4wd vtec.
Could this be done with the k series engine and 4wd box/diff from a freelander?
Had a look at the freelander gearbox and it looks about the same as 2wd but with just a bit added on the back.
What about the rear diff. should i mount a Mini front subframe in the back and lock the steering?, or is there someone (or plans) to make radius arms with a hole for driveshafts?
Cheap as possible please.
here is a pic of a freelander gearbox.
Posted 09 November 2011 - 01:53 PM
Posted 09 November 2011 - 07:40 PM
I want it 4wd to handle a big increase in power through 10inch wheels, i want to do hill climbs and such. Dont want an off road Mini.
Its mainly a question about is the gearbox and rear diff suitable for doing this conversion?, is there anything that always go wrong with them? and could it cope with 200bhp +. (maybe).
I was going to just buy a freelander petrol and sell off the unused bits. prob end up getting the bits i want for very little.
Posted 09 November 2011 - 09:12 PM
Biggest issue is the transfere case is exactly where the steering rack usually is..
Posted 10 November 2011 - 07:52 AM
Do you know they get around it when putting in the vtec crv gearbox?
Posted 10 November 2011 - 07:56 AM
Posted 12 November 2011 - 09:55 PM
would seriously say not to bother, if you want something to handle id go mid engine. but, you'll struggle with 10's on that setup.
Posted 13 November 2011 - 03:02 PM
I honestly think that front engine and rear wheel drive offers the best mix of characteristics with weight trade off. Hence why I'm trying to achieve that. I am using a freelander rear diff.
Posted 14 November 2011 - 12:00 PM
You really don't need 4wd for a mini convertion. I looked at the potential options when I was developing a concept for my project and I came to the conclusion that the additional weight and complexity didn't make it worth while.
that sounds like a good option too. what engine you using up front for that?
I did go through the idea of motorbike up front with rear drive. wanted alot more torque and the cost of bike engines has gone through the roof.
