there has been some mis-information posted in this thread, which is always a worry when people pass it off as fact.
The ECE R90 regulation is ONLY in force for vehicles manufactured after 1999. This means that all brake pads must conform to this regulation in order for them to be able to be fitted as after-market parts. Any vehicle manufactured before this time can have pads fitted which conform to the relevant standards in force at the time of manufacture.
The legislation mostly came about due to the recent influx of cheap Chinese brake material which is substantially lower quality than OE spec. ECE R90 stipulates that after-market brake pads must perform to within 15% of the original.
the following is an extract from the
The Road Vehicles (Brake Linings Safety) Regulations 1999 Brake linings for relevant vehicles
4.—(1) Subject to regulation 5, no person shall—
(a)supply or offer or agree to supply for fitting to a relevant vehicle;
(b)expose or possess for supply for fitting to a relevant vehicle; or
©fit to a relevant vehicle,
brake linings which do not meet the requirements specified in paragraph (2)(a) or (b).
(2) The requirements are—
(a)that the brake linings—
(i)have been type approved in accordance with the requirements of the Braking Devices Directive;
(ii)have been marked by the manufacturer in accordance with the requirements of paragraph 3 of Article 6 of the Framework Directive; and
(iii)are marked and packaged in accordance with the requirements of point 4 and point 6 of Annex XV of the Braking Devices Directive; or
(b)that the brake linings—
(i)have been approved in accordance with paragraph 4 of ECE Regulation 90.01; and
(ii)are marked and packaged in accordance with paragraph 6 of that Regulation.
Exception to regulation 4
5. Nothing in regulation 4 shall be taken to apply in relation to replacement brake linings for fitting or fitted to a relevant vehicle which was first used before 1st September 1999, provided that the replacement brake linings are not such as to cause the vehicle to contravene the version of the Braking Devices Directive that was applicable to it when it was first used..
