1275 Basic Engine Rebuild Carried Over From Stupid Dumb Question
162 replies to this topic
#46 AndyMiniMad.
AndyMiniMad.
  • 3,295 posts
Posted 06 November 2011 - 01:17 PM
From top left, water pump, oil pump, Half moon seal, timing chain oil seal, ???, fuel pump, gearbox oil seal, And the bottom three are for the bin...
#47 firefox
firefox
  • 1,102 posts
  • Local Club: will find one when on the road
Posted 08 November 2011 - 03:41 PM
Well i finaly found time to put the gearbox on the block, first i checked the gaskets against the block as there was 3 for some reason,
all holes lined up, but 1 without the oil hole was a better shape, so with a 1/2'' brush with the bristles trimmed in half to make it stiffer i put a thin layer of hylomar around the edge of the block mating face, placed the gaskets on and then another thin layer on the gasket which is the mating face to the gearbox, the half moon crankshaft oil seal seemed to be a little long and i was tempted to trim it to a better length, but i had second thoughts and hoped the weight of the box would compress it, so as cooperman instructed
i put a small blob of rtv silicone at each end of the seal, and a fine line around the main bearing face where the seal sits, plonked the garbox on clamped it down and jobs a good un, just hope now it dont leak, as the gearbox was now at a working height i fitted
a aloy gearcase bush and a new oil seal to the gear rod, just as well i did there were 3 oil seals rammed in, and it still used to drip
i need to get the engine the right way up now, that should be a laugh.
#48 AndyMiniMad.
AndyMiniMad.
  • 3,295 posts
Posted 09 November 2011 - 03:33 PM
What... no pictures!! :cry: ..
#49 firefox
firefox
  • 1,102 posts
Posted 09 November 2011 - 03:59 PM
I need my Mbyts saving when i get my dti and cam disk, i tried to put the engine plate on today but found out it covered the oil galleries so i am stumped for parts, i orderd the wrong dti so i have sent for another one, got carried away putting the gearbox on
forgot to photo it and it was bloody heavy, turned the engine the right way up this morning that was heavy as well
Edited by firefox, 09 November 2011 - 04:14 PM.
#50 afoggo
afoggo
  • 163 posts
Posted 09 November 2011 - 06:03 PM
use photo bucket or flickr and you can have as many pictures as you want :D
#51 firefox
firefox
  • 1,102 posts
Posted 09 November 2011 - 06:12 PM
I have heard about this photo bucket how do you set it up ?? :unsure:
#52 Brookesy
Brookesy
  • 507 posts
Posted 09 November 2011 - 06:22 PM
Go to www.photobucket.co.uk
Then sign up. You can upload photos to the site the same as you would on facebook e.t.c.
When you have uploaded the photos there will be four codes below the images. if you copy the [img] code and paste it into the forum the image will come up :)
#53 firefox
firefox
  • 1,102 posts
Posted 09 November 2011 - 06:25 PM
Ohhhhh wow cheers bud will have a go now
#54 Cooperman
  • 23,278 posts
Posted 09 November 2011 - 06:30 PM
It's going well. You certainly put the half-moon seal in corectly. Hope you remembered the small O-ring between block and gearbox faces - please say "Yes".
#55 AndyMiniMad.
AndyMiniMad.
  • 3,295 posts
Posted 09 November 2011 - 06:31 PM
Havent got a clue its the one that was in the engine 12AH83AA metro 10.1 high comp 1275 11985/1986 the omly year it was produced
Dont know which cam was fitted in this engine and the code doesnt seam to work in the engine decoder thingy...but someone will come by soon and tell us...
#56 AndyMiniMad.
AndyMiniMad.
  • 3,295 posts
Posted 09 November 2011 - 06:35 PM
Ha Ha! yes I forgot this seal and had to take it apart again...and then fitted the half moon seal the wrong way round and had to strip it yet again...the joys!!
#57 firefox
firefox
  • 1,102 posts
Posted 09 November 2011 - 06:38 PM
Oil pump gasket and pump fitted
#58 firefox
firefox
  • 1,102 posts
Posted 09 November 2011 - 06:41 PM
I had a little panic there you mean the one that goes in the recessed oil feed pipe one about the size of a wedding ring one hole is shamfered and the other a little upstand
Edited by firefox, 09 November 2011 - 06:45 PM.
#59 firefox
firefox
  • 1,102 posts
Posted 09 November 2011 - 06:42 PM
Photo bucket wooop whooooooooooop
#60 AndyMiniMad.
AndyMiniMad.
  • 3,295 posts
Posted 09 November 2011 - 06:44 PM
Yeah thats the one...its an "o" ring...And we love Photobucket...Did you prime the pump before fitting it?
That crank tail looks a bit dodgy! is it just the picture?
Edited by AndyMiniMad., 09 November 2011 - 06:49 PM.
