My 998 Turbo
#76
Posted 10 March 2012 - 11:38 PM
#77
Posted 10 March 2012 - 11:43 PM
Thats quite high for turbo, i guessing your not planning on using too much boost then. That will be a good road engine. :)
10-12 psi max
#78
Posted 12 March 2012 - 02:39 PM
also i cleaned up the manifold and found a crack
so i will send this to be repaired :)
should i try and get someon money back off the person who sold it to me because they said it was fine?
will post some high quality ones after :)
#79
Posted 12 March 2012 - 02:58 PM
just did some high quailty ones
the crack
and nice and close
and the carb, running two 25 jets so will change them to ones more suited to the 998 :)
Edited by coopdog, 23 January 2015 - 01:36 PM.
#80
Posted 14 March 2012 - 11:05 PM
this is the list i have so far
what else do i need?
also do i need a different gasket kit for the gearbox or does this come with the engine gasket kit?
C-AEG580 - CAM FOLLOWER ISKY TYPE HI-GRADE TAPPET SET O...
GLP139 - OIL PUMP 1000CC A PLUS SLOT DRIVE
GUG701589CS - ENGINE BLOCK GASKET SET 998 A+ GENUINE UNIPAR...
AJM1250MS - HEAD GASKET SET 850/997/998/1100 ALL SMALL BO...
2A14 - PUSH ROD 850/998,11OO
C-AJJ3385 - MINISPARES MOLYBDENUM CROSS PIN DIFF
C-AHT54 - OIL PIPE HITECH CENTRAL PICKUP GEARBOX
GFE166 - OIL FILTER SPIN ON TYPE 1973 to 1996 (GFE443)
thank you
callum
#81
Posted 15 March 2012 - 12:17 PM
#82
Posted 15 March 2012 - 02:11 PM
Why you buying pushrods?
thought it would be a good idea,
do they not wear?
#83
Posted 15 March 2012 - 11:46 PM
#84
Posted 17 March 2012 - 01:04 PM
Not really and any small amount of wear will be canceled out when you adjust the tappets
thats off the list now :)
this is what i have now :)
AEG584 - CAM FOLLOWER WITH OIL HOLE,MINIPARES CHILLED ...
AJM202MS - BLOCK GASKET SET SMALL BORE PLUS COOPER S
AJM1250 - SMALL BORE COPPER HEAD GASKET SET 850/998/110...
AJM804B - GEARBOX GASKET SET
GAP413 - YELLOW ENGINE SPRAY (AEROSOL NOT TO BE SENT ...
got to get some engine mounts but i want ones that wont give me any problem :/ how are the ones from huddersfield?
and i dont want to use minisport :L
anything else?
#85
Posted 06 April 2012 - 11:05 AM
seeing as money is tight im not going to buy the diff as that would put my budget over a bit so im gonna leave it until i need it
#86
Posted 06 April 2012 - 04:24 PM
anyway thats just me rambling on like a mad man... nice build! you running dished or flat top 998 pistons?
#87
Posted 06 April 2012 - 09:47 PM
random side thought... but im sure you could run a 36mm weber downdraft TB off a 90's fiat of some sort on that manifold. connections look very similar indeed... they came on uno's and cinqs.
if you could find, no harm in trying :L
the 998 is the flat top version :)
#88
Posted 24 April 2012 - 02:59 PM
Just waiting on them and then it's all getting started woo!
#89
Posted 27 April 2012 - 07:46 PM
just got to order a few more things and its ready to go!
#90
Posted 27 April 2012 - 08:18 PM
