Supercharger Systems
22 replies to this topic
#1 JonBooth
JonBooth
  • 113 posts
Posted 25 October 2011 - 11:11 PM
Hello all,
I've just agreed my final year degree project, I'm studying Automotive engineering at Sunderland Uni and I'm looking at the supercharger systems that are currently available on the market for the Mini... Analysing the benifits and limitations of each system with the aim of producing an improved manifold design.
If you have a supercharged classic Mini, it would be great if you could attach a photo of your engine to this post with the engine specs and power figures of your set up.
Thanks in advance.
Jon.
#2 new_zealand _minis
new_zealand _minis
  • 654 posts
  • Local Club: wellington new zealand
Posted 26 October 2011 - 08:31 AM
ive got some real nice new pics of my setup but i cant upload them:(
#3 JonBooth
JonBooth
  • 113 posts
Posted 26 October 2011 - 01:21 PM
Ah I see, well if you can, give me a shout. Even so, if you don't mind me asking, what spec is your set up and how much power/torque are you producing?
Cheers, Jon.
#4 Gr4h4m
Gr4h4m
  • 1,802 posts
  • Local Club: Club less.....
Posted 26 October 2011 - 09:36 PM
998cc (Built in 1969 all Stadard inc gearbox)
12G295 Head 8.7:1 CR Minispares EN race spec valves
Water injection at 5PSI (.70 nozzle before charger)
Bike Carb
SC12 supercharger 7-10PSI (Dependant on Revs)
#5 JonBooth
JonBooth
  • 113 posts
Posted 27 October 2011 - 06:49 AM
Thanks very much for the reply, that looks great, never seen a set up like that one before.
#6 new_zealand _minis
new_zealand _minis
  • 654 posts
Posted 27 October 2011 - 07:20 AM
1293cc . fully forged ballenced lightend . 276 cam . hif44 aldon dizzy .( soon to be megajolt) power unknown never had it on a dyno
Edited by new_zealand _minis, 27 October 2011 - 07:24 AM.
#7 JonBooth
JonBooth
  • 113 posts
Posted 27 October 2011 - 08:34 AM
That's great, thanks again for the pictures. Does the copper coil around the inlet pipe work to stop the icing problem?
#8 new_zealand _minis
new_zealand _minis
  • 654 posts
Posted 27 October 2011 - 08:47 AM
yes it does .and it has a in filter heater
#9 JonBooth
JonBooth
  • 113 posts
Posted 27 October 2011 - 11:02 AM
Ah I see, cool stuff.
#10 Sam Walters
Sam Walters
  • 2,765 posts
Posted 28 October 2011 - 12:51 AM
Suck through vs blow though is what you should be looking at if you're looking at supercharger systems alone.
I would eliminate induction type from the project really and look at injection. But not just chucking a throttle body in place of the carb.
Take a read through this.
http://www.starchak.ca/efi/siamese.htm
#11 new_zealand _minis
new_zealand _minis
  • 654 posts
Posted 28 October 2011 - 08:02 AM
there are heaps or options out there for power . just find what one fits your budget .. there are always people that say things are better ..
as with mine . i know i built that motor to wistand way more power than the eaton will chuck at it ..
i want more power but i just wont see it with eaton suck through .. i just dont know if i want to go through the hassle of it anymore and the cash
or i would go turbo
just going to do megajolt to sort out the pinking ( that the aldon dizzy shuld have ) then i will leave it
Edited by new_zealand _minis, 28 October 2011 - 08:04 AM.
#12 JonBooth
JonBooth
  • 113 posts
Posted 28 October 2011 - 09:36 AM
Thanks for the reply, yeah that is probably going to be the main focus, there are arguments for each depending on the required power. I'll have a look, cheers.
#13 Sam Walters
Sam Walters
  • 2,765 posts
Posted 28 October 2011 - 03:02 PM
Well, i wouldn't say there are arguments for each. The single point injection injection system on the 5 port doesn't solve the problem really. All it gives you is slightly more control. You still get the same problem of fuel distribution with the carb, in fact id say its possibly worse due to shots of fuel being fired as opposed to constant atomisation.
If you look at the kit from specialist components, they will argue the point with you all day long. But you pull a head off an engine that their injection system has been on. The outer cylinders will run leaner.
#14 yeti21586
yeti21586
    He's A Lumberjack And He's OK
  • 3,724 posts
  • Name: Chris
  • Local Club: None
Posted 28 October 2011 - 03:08 PM
this is a blow through set up some one posted up a couple of years ago.
YetI
#15 MIGLIACARS
MIGLIACARS
  • 2,057 posts
Posted 28 October 2011 - 04:50 PM
