Does anyone know if you can remove the gear change mechanism from the top of the gearbox without problems as it would make it easier to modify the connection pegs to attach the cable rose joints.to?
Thanks Greg
Vtec Gear Change Connections
GregMcN2
, Oct 23 2011 08:15 PM
7 replies to this topic
Posted 23 October 2011 - 08:15 PM
Posted 24 October 2011 - 09:19 AM
Why do you want to remove the connection pegs?
If it is because the horizontal fitting is a major pain in the ar5e to get a nut on the bottom of then I can suggest a fix. Use an M6 rivnut in the hole of the connection peg and then wind a nut onto the stud of the rose joint. When you connect the rose joint stud into the rivnut of the connection peg lock it off with the nut that you had previously wound onto the stud of the rose joint.
Posted 24 October 2011 - 11:29 AM
Why not add some pictures to your project thread
Posted 24 October 2011 - 11:54 AM
I will try and get some photos later, my main problem is my iphone camera is fecked so I need to remember to take a camera with me to the garage, its a p.i.t.a. not having a camera on my phone - how I survived without one I will never know
Posted 24 October 2011 - 07:39 PM
Greg, here is what I mean in the photo below, I cant show it with the cable connected as you will notice that the gearbox isnt currently in the car.
Posted 24 October 2011 - 09:41 PM
Actually I was only really thinking about difficult access to drill out rather than problems with nut fitment and possibly more with the vertical arm than the horizontal one. I was thinking about just cutting threads in the holes and I could then use a nut to lock on top or if I could take the mechanism off then I could put a set screw through from underneath. Given restricted access I was worried about being able to drill the holes accurately.
Rivnut is an interesting idea and maybe easier than cutting a thread though isn't the metal a bit thick? My worry with rivnuts is that you start with a bigger hole so if you have problems you have no options.
Thanks Greg
Thanks Greg
Posted 25 October 2011 - 05:28 PM
Hi mate I had the same problem with my monte Carlo vtec there's a cap head bolt on the side of the gearbox undo that and it all comes out ,
Posted 31 October 2011 - 12:36 PM
As you said if lifts straight out once you have undone the cap bolt on the side and much easier to work on with it off the engine though had some problems drilling as material was quite hard - muist get some new drill bits!
Greg
Greg
