How To Get Those Tight Door/bonnet /boot Gaps
#61
Posted 17 March 2016 - 09:06 PM
#62
Posted 17 March 2016 - 09:09 PM
http://www.frost.co....14oz-414ml.html
#63
Posted 22 May 2017 - 06:41 PM
#64
Posted 14 March 2018 - 09:25 PM
Nice gaps, I have used the welding rod method before, works well! Can I just suggest that people build their doors up before adjusting the gaps, as the weight of the glass and winder mech' etc can change the doors position slightly, don't want to go through all that and have paint rubbing off when you open and close the door! ( I learnt this through personal experience
In BIW they would hang a weight on the door to simulate a fully trimmed door, once it was profiled they would remove weight and door would rise indicating the track profile for operators, one thing people may not be aware of is that they would also jack the door aperture diagonal to help also
#65
Posted 14 March 2018 - 09:36 PM
#66
Posted 08 December 2019 - 07:41 PM
#67
Posted 08 December 2019 - 07:43 PM
Reading this as my doors fit is pretty bad as its come to me.. a question the cutting and add bits to door frames especially the upper window part I take the windows themselves still fit ok ?
Its only a small amount of added material. The window fit should remain the same or very close.
#68
Posted 08 December 2019 - 08:05 PM
#69
Posted 29 December 2019 - 12:16 PM
https://youtu.be/oKtQEFoexFk
#70
Posted 24 May 2020 - 08:23 PM
Neil could you drill out the spot welds that hold the window frame into the door and move it up then re-weld it into the door rather than cutting the frame? This would raise the window frame and close the gap if the issue is only the top gap but I am not sure if the glass would fall out of the runner?
#71
Posted 24 May 2020 - 08:37 PM
You could possibly do that but the front is tapered so trying to force that up may create further issues.
#72
Posted 25 December 2022 - 07:10 AM
#73
Posted 25 December 2022 - 11:08 AM
Just read this very informative article my question is my bonnet requires the width widening slightly would it be ok to just weld on a strip of metal to the outer edge
Not really but you can slice down the edge of the bonnet with a slitting disc, open it to where you need it and then weld the slit up carefully
make sure you slit it quite a way though to retain a straight edge along the edge of the bonnet
Ben
#74
Posted 25 December 2022 - 11:15 AM
As Ben has said, you need to cut down the length of the bonnet then add a thin strip if the gap is quite large, you can just cut and using a backing piece of Copper weld the gap BUT two things here. Be careful of heat distortion and the other is evening out the gap both sides as it maybe noticeable.
On my lads car, the bonnet was crap being a Magnum bonnet and we should have chinned it off and used a Heritage one but funds were tight for a teenager. I could have been more forceful fitting the wings but here’s the rub, when I did the resto on Wills Mini Special using all Heritage panels, apart from some minor tweaking it went together really well.
My Heritage clubby bonnet needed a tapered wedge to even it up on the one side. I tried everything to get that gap even but it was actually like that before I took everything apart.
