Was that a pattern bonnet? Mine is exactly the same at the front edge. I might fix up my original and use that as it fits perfectly.
How To Get Those Tight Door/bonnet /boot Gaps
#46
Posted 25 February 2015 - 10:14 PM
#47
Posted 25 February 2015 - 10:31 PM
#48
Posted 27 April 2015 - 06:06 PM
Edited by Blatherskite, 27 April 2015 - 06:06 PM.
#49
Posted 27 April 2015 - 06:45 PM
#50
Posted 27 April 2015 - 10:16 PM
There is another trick to getting the wing over more.
You will need a helper though
#51
Posted 28 April 2015 - 09:00 AM
I found trimming the lip on the outer wing where it mounts to the inner wing really helped.
I also used ratchet straps and many many clamps
#52
Posted 28 April 2015 - 10:01 AM
#53
Posted 16 October 2015 - 01:12 PM
Some great tips thanks
#54
Posted 16 October 2015 - 01:13 PM
looking forward to getting some panel works done on my early mini, just hope we can get the fir we need
#55
Posted 17 March 2016 - 07:56 PM
This is a great topic sure it will help with my car
Any help would be great thanks
#56
Posted 17 March 2016 - 08:03 PM
#57
Posted 17 March 2016 - 08:23 PM
I bought my welding rods from BOC so there should be a local dealer near you. I used 3.2mm as this gives you plenty of leeway for grinding back. And use oxy acetylene filler rods as they are cheaper.
#59
Posted 17 March 2016 - 08:54 PM
#60
Posted 17 March 2016 - 09:01 PM
Never realised they were cheaper as we have tig rods at work so can't beat being free,
Yup its something i cannot get as a freebie so getting them cheap helps.
