How To Get Those Tight Door/bonnet /boot Gaps
73 replies to this topic
#16 Shifty
Shifty
    Sponsored by Fosters (tm)
  • 13,138 posts
  • Name: Sean
Posted 06 April 2012 - 07:24 PM
As Neil has said, grind, or even better skim the hinge in a mill. I've done this a few times now. Doesn't take much to shift it forward. On the hinge there is a stepped bit in the casting, grind this off and job done.
#17 nomininolife
nomininolife
  • 982 posts
  • Local Club: Mini Mates
Posted 10 April 2012 - 06:49 PM
Thanks for the replies guy's. No work has been done to this side of the car, with no major work done to the other side. I just dont remember it catching before I took it apart. I will try removing material from the hinge as the 'A' panel lines up really well, so I dont think its hinge panel related.
#18 1987minimayfair
1987minimayfair
  • 43 posts
  • Local Club: 16vminiclub.com
Posted 25 July 2012 - 07:18 AM
Thanks for showing how to do this
Hallam
#19 sonikk4
sonikk4
    Twisted Paint Polisher!!!
  • 16,033 posts
  • Name: Neil
Posted 25 July 2012 - 02:40 PM
No problem. :D
#20 lrostoke
lrostoke
  • 6,923 posts
Posted 29 August 2012 - 05:39 PM
I'm interested in the gap between A panel and door, just fitted new front end and rear quarter...gaps aren't bad..
Gap between A panel and Door is wider than you've achieved but looking at it if it was any thinner it looks like the door would catch the A panel when you open it, barely misses now ???
#21 sonikk4
sonikk4
  • 16,033 posts
  • Name: Neil
Posted 29 August 2012 - 05:43 PM
No problem with the door touching the A panel. Its down to how you set the door up really. The door is very slightly under proud and clears nicely. Still a tight gap though. If the door was to proud then there would be some fouling.
#22 lrostoke
lrostoke
  • 6,923 posts
Posted 29 August 2012 - 05:53 PM
that is probably where Im getting the difference, I've set mine so that the door is flush with the A panel .
Think may have to slot the hinge holes slightly to set it back
cheers, good guide :)
It is amazing the difference different parts make, my original doors I don't like the gap by the Quarter panel, so fitted a spare set off a different car, 100% better fit :)
#23 Guest_MinBinPat_*
Guest_MinBinPat_*
  • Guests
Posted 03 October 2012 - 11:01 PM
Great thread with some fantastic advise, door gaps on 'normal' minis are orrible (seen through 21st century eyes). Makes the difference between an ok job and a great one. Well done.
#24 Domeo_Jones
Domeo_Jones
  • 161 posts
  • Local Club: none yet
Posted 02 January 2013 - 05:44 PM
wow! what a good idea using the gas welding rods as a secret filler!! my welding teacher didnt teach me that! one quick question tho, may sound odd but when you were doing te bonnet the whole car looked like it had been sprayed with a dull red colour? what was that? something to stop the rust? cheers!!
i feel like a mini knowledge sponge!
#25 sonikk4
sonikk4
  • 16,033 posts
  • Name: Neil
Posted 02 January 2013 - 06:27 PM
Its just bog stock red primer from Halfrauds, i used this just as a rpotective coat while it was in the garage. It did get removed when it went to the paint shop.
#26 Domeo_Jones
Domeo_Jones
  • 161 posts
Posted 03 January 2013 - 10:49 PM
okay red primer! great was that in a can or brush? and it needs to be removed before the painting! sweet as!! just trying to soak up all this priceles info! hope to get my little beaty on the go very soon! bit scared of cuting the panels off and then finding loads of rust and not have nothing to weld the panels too! im such a newbie!! lol
#27 sonikk4
sonikk4
  • 16,033 posts
  • Name: Neil
Posted 03 January 2013 - 10:55 PM
It was cheap spray primer from Halfords. I had to remove all of it due to paint reaction. if the car is being kept inside then any bare metal areas need to be etch primed first. You can buy this from Halfords. Its made by Upol and is very good. Not cheap but you only need to dust it over the metal before using a filler primer then either another coat of primer then top coat.
If you are welding panels then use Upol zinc rich weld through primer between the mating areas.
#28 Domeo_Jones
Domeo_Jones
  • 161 posts
Posted 06 January 2013 - 10:34 PM
etch primer! that does look expensive? why do you need to etch the panel? also can you weld thru this etch stuf??
#29 sonikk4
sonikk4
  • 16,033 posts
  • Name: Neil
Posted 13 January 2013 - 07:04 PM
Sorry hadn't looked at this for a while. You cannot weld through etch primer. You can weld through Upol Zinc rich primer. The etch acts as a key for your paint ie something for it to grip to. You really need to use this on bare metal after you have finished welding.
#30 dean
dean
  • 283 posts
  • Local Club: EDMC
Posted 20 January 2013 - 03:39 PM
That u-pol stuff is good. Plus most body shops use it so may not react with other coats.
