Smiths Rev Counter
11 replies to this topic
#1 alex-95
alex-95
    I am THE CLAMP MAKER
  • 6,025 posts
Posted 17 October 2011 - 05:23 PM
I was thinking about getting a smiths rev counter but I will have an accuspark electronic ignition. So do Smiths rev counters work with an accuspark electronic ignition.
Alex
#2 Bungle
Bungle
    Original Spamster
  • 28,971 posts
Posted 17 October 2011 - 05:32 PM
they get their signal off the coil so should work
#3 L400RAS
L400RAS
  • 2,479 posts
  • Local Club: Lincolnshire Mini Owners Club
Posted 17 October 2011 - 05:41 PM
Depends on the type of smiths - RVC or RVI...
#4 alex-95
alex-95
  • 6,025 posts
Posted 17 October 2011 - 05:57 PM
This one: http://www.ebay.co.u...984.m1438.l2649
#5 Artful Dodger
Artful Dodger
    " I AM THE SPECIAL ONE"
  • 4,435 posts
Posted 17 October 2011 - 05:59 PM
older smiths rev counters dont work with any mods to the distributor, later smiths rev counters work off the coil so will work with pretty much all mods :)
#6 L400RAS
L400RAS
  • 2,479 posts
Posted 17 October 2011 - 06:16 PM
Sorry - no.
RVI and RVC Smiths rev counters each work off the coil, however those stamped RVI on the face of the tach are "induction loop type". These will not work with elec ignition. Those marked as RVC will. Please be more specific in the type proposed to be purchased - i cannot confirm which type you are buying from that photograph.
#7 dklawson
dklawson
  • 10,923 posts
  • Name: Doug
Posted 17 October 2011 - 07:27 PM
Write the seller and ask if they find RVI or RVC printed on the gauge face. OR... have them send you a picture of the back of the gauge. As stated by L400RAS, you want the RVC type tach, not RVI.
#8 Keith Grendahl
Keith Grendahl
  • 89 posts
Posted 17 October 2011 - 11:38 PM
I am using a Smiith's RVI with electronic ignition.
It may not work in all cases but on mine it was:
Green and Black to earth
Red to fuse box
Red with trace to dash lights
White and White with trace wired in series with the coil (polarity matters so if it doesn't work the first time, switch the wires)
Red wire from electronic ignition to + on coil
One white wire to - on coil, other to black wire on electronic ignition.
The online description I got it from was using a 123 ignition but works with my Ignitor as well.
Keith
#9 dklawson
dklawson
  • 10,923 posts
  • Name: Doug
Posted 17 October 2011 - 11:50 PM
Congratulations Keith. You are the second person I know who has been fortunate enough to have an RVI tach that works with their electronic ignition.
I stand by my earlier statement though. If you are buying a Smiths tach and plan on using electronic ignition, buy the RVC type.
#10 mini 4o
mini 4o
  • 318 posts
  • Local Club: corfu mini's
Posted 18 October 2011 - 12:47 PM
Attached File  smiths_tacho_1.jpg   97.67K   44 downloads
Attached File  Smiths%20Tacho%20Wiring.jpg   591.74K   60 downloads
Attached File  smiths_tacho_2.jpg   173.17K   42 downloads
Attached File  tacho.gif   29.07K   36 downloads
hi alex
take a read,
john
#11 dklawson
dklawson
  • 10,923 posts
  • Name: Doug
Posted 18 October 2011 - 01:18 PM
For another link, read the one posted below for Speedy Cables regarding the RVI type tachs. In particular, notice the VERY bottom of the page where the link points out that to use the RVI type with electronic ignitions requires a conversion process. I was serious with my congratulations to Keith. He really is only the 2nd person I know whose RVI tach has worked with electronic ignition.
http://www.speedycab...page34aaaa.html
#12 twrminisport
twrminisport
    Jesus
  • 913 posts
Rvc work. Rvi won't with the leccy ignition
JDO instruments will convert them for you though for £55
