Having Problems With Spi Single Point Injection
#106
Posted 12 February 2012 - 11:19 PM
#107
Posted 13 February 2012 - 01:21 AM
Is this thread relevant to the MPI?
Not really... though some elements are similar... the title of the thread says it all really :s
#108
Posted 29 March 2012 - 12:34 PM
I have a Japanese 2000 which is a MPI block with SPI injection, so a little different again. I am a complete mini nut and used to be in the trade importing japanese cars so have some gear still. You will probably have seen my mini at some of the shows or know me from other forums, Black Japanese ERA J666ERA.
The 2000 M-SPI wont start from cold, injector seems to be firing when cranking over smells fuelly, a squirt of petrol down the throttle body and floor accelerator and it bursts into life, runs fine till it gets warm then all over the place.
I have a Snap on MT2500 that I used to use for late japs and an old rover cart I got of ebay with lead and magically it talked to it so I was well impressed, I thought I would go in OBDC but that just wouldnt do anything on a Jap M-SPI, the old three pin in the engine bay and talked to it as a 95SPI which was the last year of the old cart I had for Rovers did.
Faults were air temperature which it was defaulting, and **** coolant temperature which it is defaulting to 59 degrees **** cleared codes a few times and air temperature one goes away, still won't start, I can with the MT2500 test the injector, purge valve stepper relay and pump and all seem ok, stepper doesnt seem to increment on the increase decrease settings but dont know if they work as never saw or did anything like this on a SPI before. Ok, came to it in its I wont start mode, and fired the injector via the MT2500 and it squirts lots of fuel so that rules out low fuel pressure blocked filter etc etc, if the coolant sensor is completely shot would non starting be the symptom, will the TPC not be powered if the coolant temp is being defaulted to 59? I assume the rough running when warm is due to the actual temperature again now being higher than 59.
Thoughts??
#109
Posted 03 April 2012 - 10:30 PM
Edited by mymini1, 03 April 2012 - 10:31 PM.
#110
Posted 03 May 2012 - 07:24 AM
Just read all of this, fantastic work.
Thoughts??
if the coolant temp sensor is open circuit (disconnected / break in wire / etc) then MEMS defaults to 59degs.
Yes if the engine is cold, then its not going to start very easily if the engine management thinks its at 59degs...
So, do check wiring and connections to the coolant sender - obviously check the sender itself to see if that is at fault...
#111
Posted 21 May 2012 - 06:15 PM
#112
Posted 23 May 2012 - 05:10 PM
#113
Posted 15 August 2012 - 08:04 AM
#114
Posted 01 October 2012 - 11:06 PM
#115
Posted 06 October 2012 - 10:32 AM
Our Equinox was having real trouble accelerating in 3rd and 4th gear (really chuggy - is that a real word?)
Checked the capillary to the ECU and it was "less than a perfect fit (it had distorted) so I used some silicone fish tank tubing as an insert to make the seal perfect and..
The car runs like a dream, more power in all gears. No more hestation.
Thanks Sprocket
#116
Posted 12 November 2012 - 06:47 AM
Long story short, on days over 35 degrees the car will start and instantly rev out to 3000 rpm.
On colder days (under 20) the car is fine. Occasionly when driving around on a 25-30 degree day the car will rev out to 3000 by itself, but settle again after a few seconds.
On a 30-35 degree day it will do its trick more often, and if the AC is on it makes the problem worse.
Problem is definitely electrical, you can see (and feel) the stepper motor doing this, so I'd think it's not a vacuum leak.
I'm going to try and get a new air temp sensor for it. I've tried the TPS and its not that, and I don't think it would be coolant temp as it does it from cold on a hot day.
Anyone seen this before?
Thanks.
#117
Posted 04 December 2012 - 11:00 PM
After a while it had warmed then suddenly the engine revs rose from the good steady idle it had been doing to about 3000rpm. Now whenever I start the car it revs up to about 3000rpm and slightly increases then stays there.
I think the temperature gauge was not showing anything when the engine was hot and it started doing this. Could a faulty temperature sensor cause this sort of high rev idle? Also I recently did an oil change and the car started smoking more, probably valve stem seals, could the oil have clogged up the o2 sensor?
I have put a short video on youtube
Thanks for any help
#118
Posted 23 December 2012 - 01:08 PM
I took off the manifold and change the temp sensor, this probably wasn't the problem as the resistance of both the new and old sensor were the same. I changed the hoses and fuel trap then put it all back together. Started it up and it ran better than before the problem with the revs really started.
The problem was either a hole or blockage in the vacuum hose or the connector on one of the many sensors had a bad connection. I did also find the end of the crank case breather hose had a small split in it so air might have been getting in there.
While I had it apart I use my multimeter to test the other sensors functioned.
Could anyone tell me how you are supposed to change the hoses without taking of the manifold and using a small hammer, my replacement hoses were from mini spares and seemed very tight?
This actually turned out to be quite a long update and a question.
#119
Posted 02 January 2013 - 10:51 PM
I wondered what might cause a lack of power? My little spi has no power over 4k and isnt exactly rapid below this mark. Thanks so much in advance. JP
#120
Posted 05 February 2013 - 11:16 AM
I replaced the air inlet sensor with a new one and the car has never reved as high as 3000rpm on its own since.
After a long run down the freeway though the car does seem to idle at 1300 rpm though.
I've ordered a new water temp sensor and will probably replace the exhaust sensor too.
My alternator has also died, so a new one there too. Expensive month!
New problem today - car wont idle. It just hunts. Seems like I have another vacuum leak / blockage.
