#91
Posted 06 April 2013 - 03:44 PM
Almost makes me want to get my hands on a welder and a rusty Mini...
#92
Posted 06 April 2013 - 04:21 PM
Once sill and A panel are on, I can tackle the other side.
#93
Posted 06 April 2013 - 06:20 PM
Keep up the good work, Darren
Edited by Minidarren83, 06 April 2013 - 06:44 PM.
#94
Posted 06 April 2013 - 09:05 PM
Ive got a home built modified metro frame, keeping the metro running gear etc.
#95
Posted 06 April 2013 - 10:22 PM
#96
Posted 14 April 2013 - 03:42 PM
#97
Posted 22 April 2013 - 07:08 PM
#98
Posted 22 April 2013 - 07:11 PM
#99
Posted 22 April 2013 - 07:18 PM
Kept the original jacking points as it was solid n its more original/correct.
I take it , those are 1 near heal-board and 1 close to flitch, what about tne hole near the B-post?
#100
Posted 22 April 2013 - 07:29 PM
Both sides are the same.
The car has never been welded from new until now.
#101
Posted 22 April 2013 - 07:33 PM
Theres a larger hole near the B post which was left open on the original ones, so ive assumed its left open on the replacements.
understood, as I am doing an estate now, I might weld a jacking point where that hole is on each side, wont see it but if one day it is needed there will be some strength there.
cheers
#102
Posted 22 April 2013 - 07:37 PM
I just need to finish the spot welds onto the door step and that sill is just about finished for now. Move onto the A panel. probally get that done at the weekend.
#103
Posted 22 April 2013 - 07:48 PM
Id never jack from there, but its orignality and that so kept them. I added a seam of weld to them just to beef them up before fitting the new outer sill.
see what you mean now with not using that hole, was just a thought. Ace project by the way and lucky to find him in such a good state. Have fun with yr a-panel.
#104
Posted 22 April 2013 - 07:52 PM
Progress been a little slow this month, due to other cars, stuff going on etc. Hopefully get a good crack at it on sunday.
#105
Posted 06 May 2013 - 01:50 PM
Spot welded the door step to sill, but wasnt happy with it, maybe need to look at that again in future, spot welder didnt seem right.
Anyway, on went the A panel. Havent got the tool with me so had to resort to hammering the lip over and then using grips with a block of wood to pull the lip in tight.
Gave it a splash of blue paint to protect it from rusting.
Started cutting out NS floor and then the grinder went kaput! doh!
Also tagged with one or more of these keywords: van, estate
Projects →
Mini Variants →
Australian 1970 Morris Mini K VanStarted by braad , 16 Mar 2023 van |
Projects →
Mini Variants →
1977 Portuguese Ima Van With LiftgateStarted by one60 , 22 Sep 2022 van |
Projects →
Mini Variants →
Mini Van Fuel Tank FittingStarted by Dylpants80 , 29 Jan 2022 van |
Projects →
Mini Variants →
Mini Van RestorationStarted by DJStrange , 21 Feb 2019 van |
Projects →
Mini Variants →
1974 Mini Van - Back To Basics BuildStarted by Vudu , 13 Jan 2019 van |
