72 Clubvan Estate (Keeping The A-Series Now)
van estate
179 replies to this topic
#166 Jordie
Jordie
  • 13,567 posts
  • Name: Jordan
Posted 12 March 2014 - 08:27 PM
Well decided to repair the rear doors, So did the NSR one today. Had to remove skin, repair frame, fit new skin, grind back etc.
1896738_10153994363870647_654062844_n.jp
1798415_10153994364025647_705075301_n.jp
1920488_10153994364195647_1652894347_n.j
Need to repair the OSR one later this week. Both doors were originally creased/damaged from a rear end bump. The OSR door will require a frame repair at the top.
Jordie
#167 hoody99
hoody99
  • 699 posts
Posted 12 March 2014 - 11:07 PM
Still think the one piece will be worth the effort look much better
#168 Jordie
Jordie
  • 13,567 posts
  • Name: Jordan
Posted 13 March 2014 - 06:52 AM
Ive had one piece before, wasnt sure back then, now ive repaired one door, I can see the two doors suit it better in my opinion.
#169 Archived2
Archived2
  • Archived
  • 1,093 posts
Posted 13 March 2014 - 06:32 PM
My vote for steel doors.
#170 domdee
domdee
    Formally known as dominicdee
  • 1,183 posts
Posted 14 March 2014 - 06:51 AM
go for the two doors! not a fan of the one piece fg
#171 Jordie
Jordie
  • 13,567 posts
  • Name: Jordan
Posted 30 March 2014 - 06:12 PM
Havent updated this, but i did repair the other door. Still needs the repair doing at the top, but I got called away half way through doing the door. With other stuff going on, I havent had time to do anything this week but need to crack on with it.
#172 Jordie
Jordie
  • 13,567 posts
  • Name: Jordan
Posted 13 April 2014 - 07:41 PM
Typical, run out of welding wire when I needed it most....
Fitted the passenger door. This as been repaired prevously using a gen skin. I have shimmed the gap so it opens and closes ok. I arent happy with the shape of it above the wing mirror/start of door frame area.
Did some prep on rear doors, touch of paint. Still got to repair the upper part on OS door, but no welding wire!!!
Jordie
#173 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 21 April 2014 - 01:22 AM
Great stuff mate!
Glad you kept the steel front. I hate FG ones :X
So will it be ready for IMM?
Ben
#174 Jordie
Jordie
  • 13,567 posts
  • Name: Jordan
Posted 21 April 2014 - 07:23 AM
Finished the OSR door welding, fitted false floor in boot, started the front to rear wiring loom etc.
Doubt it will be ready for IMM.
#175 Jordie
Jordie
  • 13,567 posts
  • Name: Jordan
Posted 21 April 2014 - 08:10 PM
Done some work on the gearlinkage hole, so the rod change fits.
Then trail fitted some doors, found drivers door which fits good. Frame is ok, but previous repair/damage by an owner means theres some filler work to be done.
10151426_10154139796765647_4923496959751
#176 Simon.rob
Simon.rob
    Starting My Mini Up
  • 1 posts
Posted 05 May 2014 - 12:10 AM
This is looking good! Learning a lot from this post keep it up!
Si
#177 minivan1976
minivan1976
  • 58 posts
  • Local Club: LSMOC
Posted 24 May 2014 - 01:19 AM
looking good Jordie  :-)
#178 Jordie
Jordie
  • 13,567 posts
  • Name: Jordan
Posted 08 June 2014 - 03:13 PM
back on it after my holidays
wired aux fuse box and fuel pump up. Connected pump to a jerry can, engine fired and running no problem.
Started to vinyl paint the top and bottom dash rails, in meantime, trial fitted the petrol tank to ensure good fit before painting the car.
Got abit less done than I wanted too due to having to do some work on my daily.
#179 Jordie
Jordie
  • 13,567 posts
  • Name: Jordan
Posted 03 September 2014 - 07:50 AM
Now sold.....moving on to a new owner to complete.
Sad times, but other priorities in life means it must go.
#180 Jordie
Jordie
  • 13,567 posts
  • Name: Jordan
Posted 27 September 2014 - 08:44 PM
Gone...
10635907_10154753065875647_9031381552106
Also tagged with one or more of these keywords: van, estate
