Straight Cut Drop Gears
50 replies to this topic
#46 oltonlad
oltonlad
  • 2,401 posts
Posted 27 May 2013 - 01:26 PM
I've got a whole Jonspeed gearbox with straight cut transfer gears for sale.
didn't that sell on ebay?
#47 Captain Mainwaring
Captain Mainwaring
  • 1,712 posts
  • Local Club: Surabaya Mini Club
Posted 27 May 2013 - 01:28 PM
what is the advantage though, the gears are fairly efficient (talking about SC) and dont take up much power to transfer the power from crank to primary shaft, you also cannot change ratios very easily at all with this, and there is a fear of the chain snapping. i only assume the gears would be stronger than the chain, but i dont know, never worked with chains!
Google range rover or pajero transfer box chain.
You can change ratios just as easily.
You won't snap that chain in a hurry.
http://c3193032.r32....1029c9b2be1.jpg
As for advantage - huge power capacity, quiet transmission without end thrust.
Edited by Captain Mainwaring, 27 May 2013 - 01:30 PM.
#48 E.L.M.O
E.L.M.O
  • 3,953 posts
Posted 27 May 2013 - 08:46 PM
It's still for sale
#49 AndyMiniMad.
AndyMiniMad.
  • 3,295 posts
Posted 28 May 2013 - 11:30 AM
Deleted
Edited by AndyMiniMad., 28 May 2013 - 11:35 AM.
#50 AndyMiniMad.
AndyMiniMad.
  • 3,295 posts
Posted 28 May 2013 - 11:33 AM
These are the roller bearing type from MED. Strong and not quiet as noisy as the type that use the original idler bearings, but pretty expensive.
But as already mentioned by Guessworks, don't forget one of these.
#51 Orange-Phantom
Orange-Phantom
  • 614 posts
Posted 28 May 2013 - 12:33 PM
I've got a straight cut box with straight cut drop gears and don't find the noise from it that bad, the engine noise is louder than the gearbox!
The slightly funny noise is the gain setting being to high on the mic and not the car (thankfully).
The gearbox is in 4th gear on the vid so most of the whine is from the drop gears (Jack Knight versions).
My Bro has the Med drop gears and again yes they are noisier than the helical versions I wouldn't say they make your ears bleed.
The older drop gears he used to have were very noisy though (I'll find out what they were).
Edited by Orange-Phantom, 28 May 2013 - 12:51 PM.
