Welding With Co2
13 replies to this topic
#1 R2D2
R2D2
  • 41 posts
Posted 13 October 2011 - 09:41 PM
has anyone had any experience welding with just co2? I hear argon mix is the best way to go but i've also heard co2 on its own. Any advice? Cheers
#2 andymini12
andymini12
  • 812 posts
Posted 13 October 2011 - 09:51 PM
Co2 works ok on its own, but the weld seems to come out nicer and stonger with argon mix i have found.
EDIT: also i found there seem to be a little more splutter with CO2.
Edited by andymini12, 13 October 2011 - 09:52 PM.
#3 Tupers
Tupers
  • 4,143 posts
Posted 13 October 2011 - 09:57 PM
In my experience pure co2 seems to cause more splatter than argon mix is a viable alternative.
#4 minikidx14
minikidx14
  • 1,387 posts
  • Name: Ross
Posted 13 October 2011 - 11:21 PM
I prefer pure co2 then an argon mix. I assume you mean mild steel mig welding?
#5 R2D2
R2D2
  • 41 posts
Posted 14 October 2011 - 09:04 AM
yeah mild steel mig welding. Some people say that the welds are weaker and others say they are just as strong just a more untidy weld.
#6 Danpolk
Danpolk
    Previously known as 206boyracer
  • 220 posts
Posted 14 October 2011 - 10:28 AM
not sure about the strength but co2 makes a lot more spatter. Also the welds tend to be higher!
#7 Tupers
Tupers
  • 4,143 posts
Posted 14 October 2011 - 11:44 AM
From what I've read the welds are normally higher with co2 because it cools the weld pool more than argon mix meaning the penetration isn't as good. When I was welding with co2 I just wound the temperature up a little more than I would for argon mix until I got a level of penetration I was happy with.
Just one for the road, penetration. :teehee:
#8 Frisco
Frisco
  • 414 posts
Posted 14 October 2011 - 03:52 PM
It really depends where you get the gas from. Pub gas often has moisture in the cylinder which comes out when your welding.
IMO argoshield light is ideal for pretty much for everything on a car
#9 R2D2
R2D2
  • 41 posts
Posted 14 October 2011 - 05:24 PM
i've heard that fire exstinguisher places will refill bottles aswel.
#10 R1minimagic
R1minimagic
  • 4,660 posts
Posted 14 October 2011 - 05:27 PM
It makes sense, all in line with global warming etc etc
I also find pure argon is quite sputtery!
#11 Andyagl
Andyagl
  • 241 posts
Posted 18 October 2011 - 01:24 PM
i always weld with just C02. I find my penetration is good enough. ;D alot of the time i can feel the weld on the other side too. so going all the way through, but not making a hole.
#12 BMH
BMH
  • 108 posts
Posted 30 October 2011 - 12:18 PM
Using co2 creates a hotter weld which can result in quite a bit of warping if your not carefull, i can let you have an empty co2 bottle and give you the number of a guy in brighouse who can exchange it for you, and fire extinguisher companys won't fill a pub bottle as it is illegal and carries something like a 20 grand fine if caught.
If your interested in a bottle drop me a pm.
Bryan
#13 JustSteve
JustSteve
    Puke-Boy!!
  • 1,883 posts
Posted 30 October 2011 - 12:21 PM
I've only even used Co2... mainly because I've got two BIG bottles that my dad got for a tenner :o
#14 Brams96
Brams96
  • 2,308 posts
Posted 30 October 2011 - 01:40 PM
I started with just CO2 & my welds were ok but since changing to CO2/Argon (5%) mix from Adams gas I find welding easier & less messy.
Edited by Brams96, 30 October 2011 - 01:41 PM.
