Timing Alteration For Running On Unleaded
14 replies to this topic
#1 firefox
firefox
  • 1,102 posts
  • Local Club: will find one when on the road
Posted 12 October 2011 - 10:26 PM
Hi I have a metro 1275 engine High compression 12HA83AA The book says 11 Degrees BTDC
this is for leaded petrol do i need to adjust it for unleaded, the reason i ask is i had super unleaded with red-ex additive in the tank and engine was running super, today as the fuel was low i put a gallon on regular unleaded in as i thought i had over dosed the redex last time and it ran like crap popping and juddering any thoughts would be great
#2 Frisco
Frisco
  • 414 posts
Posted 13 October 2011 - 06:38 AM
Super is 98-99 depending on where you got it and regular is 95ron so yeah the ignition timing is different between the two.
Redex makes no difference
#3 dklawson
dklawson
  • 10,923 posts
  • Name: Doug
Posted 13 October 2011 - 12:42 PM
As Frisco said, the timing settings need altering based on the octane rating of the fuel, not so much whether there is lead (or lead substitute) in the fuel.
In general, you retard the timing more and more as you run lower and lower octane fuel. This will prevent knocking and pinging but it comes at a price in power. More retarded timing = less power. However, advanced timing with low octane = pinging & knocking = reduced engine life. It's a trade off really.
#4 firefox
firefox
  • 1,102 posts
Posted 13 October 2011 - 12:49 PM
so am i better off using super unleaded it seems to run cooler on that
#5 firefox
firefox
  • 1,102 posts
Posted 13 October 2011 - 01:40 PM
I have changed the petrol back to what i had someting has goge drasticly wrong i have had the timing from 4 btdc th 16 btdc with the vacume off and i cant stop the engine popping and it is quite loud i have changed the coil and still the same the dizzy is a new 65dm4 where do i stast looking carbs ignition for the first time today i turned off the ignition and it run on reved up and died
Edited by firefox, 13 October 2011 - 01:43 PM.
#6 Ethel
  • 25,914 posts
Posted 13 October 2011 - 02:45 PM
Have a look at the plug colour after a run at least long enough run up to get it up to temperature.
Ignition advance & fuel mixture both have an interconnected effect. It could also be carbon build up, spark plug or valve issues.
#7 jaydee
jaydee
  • 8,565 posts
Posted 13 October 2011 - 02:51 PM
I've noticed that a tuned a-series engine doesnt like more than 30° maximum advance with modern fuels..
By the way 'the more the advance-the more the power' does not suit very well with higher volumentric efficency engines..
Unleaded also needs higher burning temperature to give its best.
#8 firefox
firefox
  • 1,102 posts
Posted 13 October 2011 - 04:49 PM
just had the head done a few weeks ago new springs stem seals gasket and made sure exhaust was air tight, just checked spark on all 4 plugs they are fine ,i am sure it is fuel related , got the carbs off ebay and spent a fortune on them i could have bought new ones, i have a HIF44 i might put that on and see if it runs better
#9 firefox
firefox
  • 1,102 posts
Posted 13 October 2011 - 04:53 PM
Yeah noticed it is running very hot book says 11* btdc is that about right ??
#10 firefox
firefox
  • 1,102 posts
Posted 13 October 2011 - 04:59 PM
I have set the mixture as haynes manual with the lift pin contact the piston lift 1mm is revs drop off to weak if revs rise to rich
but the left carb i have had to wind down about another 8/10 turns the right one nill only the basic setting 2 full turns now it wont chuffing start, i am pulling my bloody hair out here
Edited by firefox, 13 October 2011 - 05:00 PM.
#11 firefox
firefox
  • 1,102 posts
Posted 13 October 2011 - 05:21 PM
Anybody know the needle size for my engine for a HIF44
#12 diogoteix
diogoteix
  • 170 posts
  • Local Club: Mini Club Portugal
Posted 13 October 2011 - 06:09 PM
98/99 RON versus 95 RON fuel makes quite a difference. I've experience some pinging issues when putting 95 RON fuel because there was no higher grade available at the station.
Leaded/unleaded fuel makes no difference, except for lubrication purposes. The advance your engine will be comfortable with will depend on 3 main external factors (apart from load/rpm): fuel RON grade, engine intake air and water temperature (the higher the temp, the less advance it will be comfortable with).
#13 jaydee
jaydee
  • 8,565 posts
Posted 13 October 2011 - 06:10 PM
BDL ?
#14 firefox
firefox
  • 1,102 posts
Posted 13 October 2011 - 06:22 PM
BDL ?
i gather that is the needle or are you swearing at me ha ha ha ;) had a bad day which is best twin hs2 or hif44
#15 jaydee
jaydee
  • 8,565 posts
Posted 13 October 2011 - 09:36 PM
BDL ?
No thats the needle ;)
Keep your HIF44, really, just set it spot-on and it will be perfect for a 1275.
